First post, by oeuvre
Gateway 700s Essentials case
Antec EarthWatts Green EA-380D 380W ATX power supply
Arctic 92mm fan
Gigabyte GA-EP43-UD3L LGA775 ATX motherboard
Intel Core 2 Quad Q9400 2.66GHz quad core processor
ThermalTake Contac 12 cooler
8GB DDR2 RAM
3.5" floppy drive
DVD/RW SATA drive
DVD-ROM IDE drive
3.5" USB 2.0 + USB 3.0 front panel
Western Digital VelociRaptor WD1600HLFS 160GB 10,000RPM SATA HD
Toshiba 128GB 2.5" SATA SSD
Windows XP Professional
Windows 7 Professional 64-bit dual boot
AMD RADEON HD6570 1GB PCIe video card
Onboard gigabit ethernet
Onboard audio
Creative SoundBlaster Live! PCI sound card
Sony ENX-26 Gigapocket PCI TV tuner
USB 3.0 PCIe card
Everything works perfectly except for the power LED and front FireWire.
The rear, with a crappy dremel job for the motherboard's ports
The guts
Messy cables galore!
BIOS screen
Windows XP desktop
Programs + specs
Windows 7 desktop
Specs. Good XP gaming rig.
Reply 1 of 7, by Almoststew1990
Blimin 'eck, those cables!! Please sort them out!
I've always preferred higher clocked dual cores over quad cores when I cobble together a "I can't be arsed to retro" late XP build. I have an C2D e8600 3.1GHz with an Nvidia GTX645, and I haven't needed to overclock either the CPU or GPU for my XP gaming. it's also nice that it is basically silent. I'd be interested on how your CPU performs for late XP / Vista (basically 'disk based') gaming.
Reply 2 of 7, by KCompRoom2000
What a cool system you got there. If that was my computer, I would've spray painted the DVD-RW drive and 3.5" USB port bezels beige to match the case, but that's just me.
It's also neat to see the Gigabyte OEM logo on the system properties on the Windows XP partition (side note: I'm looking for an ASUS OEM logo).
Reply 4 of 7, by Intel486dx33
Please be careful with that back I/O area.
Maybe build a cover out of plastic using a Dremel tool.
And at least file down the sharp edges.
I hate shape edge cases, Have cut myself may times with cheap cases. Not worth it.
I purchased an HP Media Center PC with Core-2-Dual for $30.
It does not have a hard-drive but that okay because I plan on putting an SSD in it an upgrading the CPU to Core-2-Quad.
It is loaded with components like your PC.
    269.87 KiB
    24.3 KiB
Reply 5 of 7, by dr_st
I must say that the combination of black + beige front panels + grey panel makes the case look eerily aesthetic.
And I love your cable management. Most of my cases look exactly like this. Cable management is one of the most over-rated things. It looks nice when everything is static, but every time you try adding something that wasn't originally there or replacing a faulty cable, all hell breaks loose.
Although I cannot understand why you need a DVD IDE drive. And that back panel is a nightmare, in terms of aesthetics, safety, dust - everything really. Can't you get a proper shield?
Congrats on a nice build!
Reply 6 of 7, by dr_st
Most KMS/SLIC cracks will inject these for you. 🤣 But we only deal with legit software.
Reply 7 of 7, by oeuvre
For the OEMLOGO, I always just install it manually. This guide shows you how to do it for free, legally.
https://www.howtogeek.com/howto/windows-vista … -windows-vista/
And yeah, I just did a quick dremel job on the rear... it just had the cutouts for the original P4 Gateway motherboard ports so I cut around those. The edges aren't sharp actually and I filed them a bit. I left that DVD IDE drive in there to fill the 5.25" bay.
