First post, by Eleanor1967
I recently bought three ET3000AX cards, but since initial testing all three started to artifact (maybe I just didn't notice earlier, though, I just quickly checked for a signal and called it a day). I have no experience with troubleshooting such old cards so any help would be appreciated. My first thought would be memory, but getting the original HY53C464LS-80 is quite pricy and so I wanted to ask for opinions first.
Tested on two different boards, a highend 486 and a really low end 386.
Best regards
Eleanor1967
    1.19 MiB
    Artifacts get worse over time, like they are continually filling up the screen
    770.18 KiB
    Smaller artifacts in graphics mode
    924.18 KiB
    Big artifacts in text mode
Reply 2 of 10, by MMaximus
This won't answer your question, but I have a similar card and posted a topic about it a while ago. Sadly not much info about it I'm afraid:
EGA/VGA Optima 1024 P.N. 3071 Rev A (Tseng Labs ET3000AX) info or manual?
Hard Disk Sounds
Reply 3 of 10, by Eleanor1967
Kubik wrote:
I'm still guessing it's memory (can you swap them with known good ones from another card?) or eventually filter caps.
Well only one of my cards has socketed memory and while I do have a card which also has this memory socketed its dead and has only half the amount of chips so not really is the answer. I'm not sure what the filter caps are, would you be so kind and pin point me to the right component?
Here are the jumper settings if you have not seen them already
Reply 4 of 10, by keropi
yeah it's 99% a ram fault, don't bother with capacitors ... start changing ICs one-by-one until you don't get artifacts then throw away the defective memory IC.
Reply 5 of 10, by Eleanor1967
After spending at least an hour swapping memory chips left and right I realized that I do have a card which uses the same memory and is known good. Well long story short it's not the memory. Swapped the memory in from the know good card and it's still artifacting, swapped it back and the other card is still working perfectly. I will test the other memory chips in this card at a late date just to be sure though.
I did learn a lot about the card though.
- It needs at least 6 memory chips to produce its normal picture
- It needs at least 2 to work at all
- If you go down to one you have to go up to three again to make it work again
The new picture is with the known good memory chips, so some new artifacts have joined the party.
I also noticed testing in EDIT for artifacts (cause the don't show up as often with just 2 memory chips) that scrolling the screen with enter seems to clear the artifacts and only produce an artifact once in a while, while scrolling with the cursor keys produces a whole rainfall of artifacts (at least that is what it looks like since the artifacts just scroll of the screen)
Maybe somebody with knowledge can make any sense of this.
    1.28 MiB
Reply 6 of 10, by keropi
Oh bad luck then 🙁 check for solder defects or damaged traces...
Reply 7 of 10, by MMaximus
Eleanor1967 wrote:
Thanks! I didn't know about this page. I might try some settings next time I pull my ET3000ax out of storage.
Hard Disk Sounds
Reply 8 of 10, by Eleanor1967
Played a bit with the cards today. The new artifacting from my last post is gone again, I guess thats good. I tested all the memory chips in my known good card and they all work fine. I also tested another DAC on one of the cards. Can't spot any bad solder points or cracks or damaged traces anyhwhere.
What about the filter caps mentioned above? What part is this?
Reply 9 of 10, by CkRtech
Could you post some well-lit, high resolution photos of both sides of the card?
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 10 of 10, by Eleanor1967
There you go. I can try again if necessary.
https://www.dropbox.com/s/6rin7lcls9yo6i2/et3000ax.rar?dl=0
I also tried the oven trick with one of the cards but it didn't work. Fresh out of the oven still a bit warm the card was artifacting hard and would crash almost instantly, the system wouldn't even finish counting the memory. After some cooling done its back to working and "normal" level of artifacting.
