Fade To Black
First post, by caltrop
This is a game from 1995.
PC & Playstation.
CD issue running in DOSBox.
CD is only single speed causing sound problems, actually NO sound!
36.14 KiB
Reply 1 of 7, by caltrop
Well...
That does not matter.
As soon as the game enters player mode it CRASHES!
DOSBox just shuts down with no messages.
Guess I'll see if I can get the Playstation Emulator going...
Hmmm...
I have DOS 6.22 & FreeDOS in VirtualBox, that might work.
VirtualBox - not much good for gaming.
FreeDOS...
I want DOSBox to work!
Reply 2 of 7, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Start the game like this: F2B -2
The -2 parameter avoids the CD speed check. However, I've not had any problem with the game crashing using default settings. Not sure what's in your FTB batch file, but try typing all commands manually when troubleshooting.
Reply 3 of 7, by caltrop
my ftb.bat
@ echo off
imgmount d "/home/caltrop/ISO/DOS/Fade to Black.iso" -t cdrom -fs iso
cd \games\f2b
call f2b
cd \
imgmount -u d
f2b is what was installed
could have a bad ISO...?
everything is fine until the game actually starts
the chunky first person character appears then DOSBox shuts down
Reply 4 of 7, by caltrop
my modified batch file
@ echo off
cd \games\f2b
call f2b -2
cd \
imgmount -u d
that ftb -2 causes immediate DOSBox CRASH!
Reply 5 of 7, by caltrop
FYI: sound is backwards
probably the HDMI output
I use the audio output from the external monitor
one less cable to plug into the computer
MY GOD! but it is always something
so far my experience with DOSBox is less than satisfactory
for that matter my overall gaming experience with Linux SUCKS! 🙁
how come the 🙁 (sad) emoticon is not in the list...
Reply 6 of 7, by caltrop
here's how to reverse the sound
pactl load-module module-remap-sink sink_name=reverse-stereo master=0 channels=2 master_channel_map=front-right,front-left channel_map=front-left,front-right
pactl set-default-sink reverse-stereo
I put that in a startup script I have to fix various things when Linux Mint Mate starts
or you can edit /etc/pulse/default.pa
OH MY...
that kinda mess up the audio system
the volume control gets messed up
pulse-audio is problematic in Linux
fun, Fun, FUN in the land of computers... 😮
