First post, by Narakir
Hello,
I've been trying to run Shadowcaster CD in dosbox, and I have a few issues related to the audio:
1) When engaging combat the music loops, until it ends.
2) I get an error after the introduction "CD error 21, back track number"
3) The voice acting doesn't seem to work either.
I've tried several versions of doxbox from 0.73 to the most recent, including builds of dosbox-x.
Here is my setup
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74.map
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=capture
memsize=16
[render]
frameskip=0
aspect=true
scaler=normal2x
[cpu]
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
…Show last 51 lines
oplrate=44100
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
ipx=false
[autoexec]
mount C C
imgmount D "CD\SHADOW.cue" -t cdrom
C:
cd castercd
shadow
