stutter in dos games
First post, by weldum
hi, i'm having some problems in my dos machine
some games have stutter when playing, aside from that everything works right
also, some games like turrican 2 have weird scrolling
the vga card is an Alliance Semiconductor AT24
the rest of the machine is:
Pentium MMX 200
64MB EDO (4x16)
PCChips M558
VXPRO II Chipset (utron)
Crystal CX4237B based sound card
Realtek 8029AS PCI
Maxtor 90845D4 8.4GB IDE
No floppy or optical drives
Windows 98SE with MS DOS mode super easy patch from Phil's computer lab
I only have that Alliance card and a trident 9440 to test, but the latter doesn't play well with my lcd monitors.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 2, by auron
VGA DOS games typically run at 70 Hz, so if your LCD doesn't properly support this you'd get stutter.
Reply 2 of 2, by weldum
no no, is not that kind of stutter, it's like when you play doom and have low ram ammount and a slow hdd, later i will do some tests with a k6-2 to see if it's solved
