First post, by MTD
Hello,
When i am running DOSBox 0.74 on Windows 10 the Windows screensaver / standby timeout will be blocked. Is there any possibility to disable this future?
For Linux i found the solution by setting the environment variable SDL_VIDEO_ALLOW_SCREENSAVER. Is there a same solution for Windows?
Reply 1 of 5, by DosFreak
Does setting that variable not work in Windows?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 5, by olddos25
Who even uses screensavers these days? Also, you wouldn't want the screensaver to activate whenever you are playing, so that's only natural. So don't get your hopes high.
Just another user that likes old OSes and videogames, nothing interesting to see here...
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
Reply 3 of 5, by MTD
I add the environment variable like this way, but it don't works. Maybe i did something wrong?
I want to achieve that the system that's running DOSBox switches to standby when running on battery power (used on industrial PC with build-in UPS; when machine power is switched of the PC must go in low-power state). This works without DOSBox running, so DOSBox blocks the Windows power saving functions
Reply 4 of 5, by olddos25
Unfortunately I know nothing about SDL, so I can't help you.
Reply 5 of 5, by collector
If you have an OLED display you will want to. OLED has a burn in problem. It is why Roku has a screensaver.
