Older hdd imaging software
First post, by Robhalfordfan
Hi all
Can someone help me with trying make a hdd image of ms-dos/win3. 11 hdd with mbr and same for win95 either over network to my nas box or USB stick
Have try different programs and they don't work because the mobo and processor that I am using are too old.
Machine is is using an atc 1000+ mobo and pemtium 133 and 81mb of edo ram
Managed to image my win98 and xp hdds to my nas storage box with acronis true image and it also restores them fine
Looking to try same thing basically
Thanks for helping if possible
Reply 1 of 24, by gca
You could try booting a live linux distro and using dd to image the drive. Either that or an older version of norton ghost if you can get one.
Reply 2 of 24, by Robhalfordfan
I never use Linux before and try with Norton ghost 2003 but maybe I am doing something wrong but could not get going properly
I was looking for older non-trial version of acronis true image that might work with older hardware but no luck in finding any older version like v8 or v9
Reply 3 of 24, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Linux would be best or anything other that is open source. The big name imagers are problematic as they can prove fatal when you want to get at the files in the image a little bit down the road.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 24, by Robhalfordfan
What do you mean fatal, If keep the discs that made the image then should be issue to restore in future
As I said I never used Linux before, so wouldn't what do to
Reply 5 of 24, by Dominus
DOSBox Moderator
I've used imaging software years ago and the images are dead because either the software is long gone from my machine and I don't know the name of it anymore (yes my mistake) - OR the software is ages old and doesn't install while newer versions don't work with those old images anymore...
Reply 6 of 24, by Robhalfordfan
Yeah I understand that and that's why I keep a copy of discs and a machine that can use it
Reply 7 of 24, by derSammler
Partition Image, runs under plain DOS.
Reply 8 of 24, by zyga64
Back in time (Windows 98) we're using PQDI (Power Quest Drive Image). Great, very intuitive software.
However this was commercial software, and may not be easy to find it today.
Edit: I just looked at eBay - there is quite a lot different versions of PQDI.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 9 of 24, by Robhalfordfan
Will have a look and see if its work with p133 and 81mb of ram
Found a temp way for now till I find software that can what I want do to, took the hdd out of the p133 machine and put it my p4 machine and newish version version of acronis true image works fine
But nae ideal cause I don't want have to take hdd out of machine to backup but for now just have to do it for now
Reply 10 of 24, by tayyare
Older DOS versions of Norton (Symantec) Ghost is what I have and use. Anything older than (and including) 2003 will be ok. Make a bootable DOS floppy, put your mouse driver and Ghost in it, and that will be all you will ever require.
I use it for all kinds of old OS parititons (MS-DOS 3.x/4.x/5.x/6.x, FreeDOS, OS/2 Warp 3/4, Windows 95/98/ME/2000) in all kinds of old machines (386, 486, Pentium, Pentium III, Pentium 4) and never had a problem.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 11 of 24, by McMick
I don't know if this helps, but Ghost was originally made by a company called Binary Research Ltd. so maybe that will help with your search. What about Partition Magic?
Reply 12 of 24, by bjwil1991
I've used Norton/Symantec Ghost 7.5 on my Windows 98SE machine to clone a 32GB HDD to a 60GB HDD (after prepping the HDD, formatting, and copying the system files) successfully (took about 4 hrs before, and it went down to 1 hr for copying every file).
Reply 13 of 24, by McMick
I was so tired when i read this thread I didn't even notice what it was all about. So why not just yank the drive from the old machine and do the image on a modern PC? (This assumes that you have access to one, of course.) Then you can use whatever imaging software you want. I prefer GPartEd 'cause it's free.
Reply 15 of 24, by Robhalfordfan
already done that and not my preferred way of doing it, cause i don't want to have to physically take it out of machine to backup but will have to do for now
Reply 16 of 24, by Robhalfordfan
lolo799 wrote:
had a look and don't think dos6.22/win 3.11 and win95 is supported
Reply 17 of 24, by lolo799
Robhalfordfan wrote:
It makes a complete dump of the full disk or of any partitions you choose, it doesn't care what system is installed as you boot it either with a set of floppies or a CDROM, it's all written in the FAQ.
Reply 18 of 24, by CrossBow777
Yeap I and my company I worked for used Ghost 7.5 on self boothing disks and CDs back then to quickly and easily restore customer computers. I even still have a set of those old self booting CDs I believe and that old version of Ghost would be on it since you only needed just the ghost.exe file. I had a batch file I created for each that would kick off Ghost and ask you various questions about the machine so it would know which image to restore when you used them. I loved old batch file menus like that back then...sigh...
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 19 of 24, by gdjacobs
Ghost is pretty good. The only weakness is the anemic networking support (depends on what's built into the DOS boot disk).
