First post, by martinm
Hello from Austria,
i hope you can help me. I try to install Jack Orlando via D-Fend reloaded. The game starts, and ends after 1 second..
I have installed also the iso file, the setup and the game.exe. Can you please have a short view over my config.file 😀
Thank you very much. 😀
sorry for my bad english 🙁
# Config file for profile "Jack Orlando"
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
usescancodes=true
priority=higher,normal
mapperfile=C:\Users\Martin\D-Fend Reloaded\mapper.map
[dosbox]
machine=svga_s3
captures=C:\Users\Martin\D-Fend Reloaded\Capture\Jack Orlando\
memsize=63
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=10
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplrate=44100
oplemu=default
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=1
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[dos]
xms=true
ems=true
umb=true
keyboardlayout=GR
[joystick]
joysticktype=none
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[autoexec]
@echo off
SET PATH=Z:\
keyb GR 437
mount C "C:\Users\Martin\D-FEND~1\VIRTUA~1\"
imgmount D "C:\Users\Martin\D-FEND~1\VIRTUA~1\JACKOR~1\iso\jack.iso" -t cdrom
echo.
C:
cd\
cd \JACKOR~1
Z:\config.com -securemode > nul
call JACK.BAT
exit
