First post, by sabbc7
sabbc7
Offline
I recently had a problem with command and conquer red alert and yuri's revenge.
My system is Windows 10, using dgVoodoo 2.
When my compatibility is set to empty, I can run the game well, refresh rate is also high, very smooth, but at this point I will flash back when playing Internet games.
When I set the compatibility to Windows 98, my game refresh rate was low, and I was able to access the Internet.
Conclusion: even if the display problem is solved, there are still many components to be solved. If the dgVoodoo 2 fits in compatibility mode, everything should work.
