First post, by mt777
I recently got CT1740 + midi daughterboard. Unfortunately there were crushed before shipping to me.
I will try to repeir them but couldn't find binaries of eproms in CT1900. Maybe somoene can dump them or know where can I find them?
SMD capacitors: C32 & C37 should be also replaced. What type are they?
    960.05 KiB
Reply 1 of 11, by root42
Are those spaghetti on the PCB??
Kidding aside on the german amoretro board someone reviewed the Waveblaster:
http://www.amoretro.de/2014/01/creative-waveb … rboard-4mb.html
Maybe you can contact him for help.
YouTube and Bonus
Reply 3 of 11, by root42
Did you try reading out the ROM chips anyway? Maybe you can salvage at least the left. And the right can't be destroyed any further anyway.
YouTube and Bonus
Reply 5 of 11, by moturimi1
You also have to replace the Wavetable Adapter.
Please desolder CT1900-U7 and read out the chip and provide the mD5 checksum or the checksum of the software from the flash rom programmer.
As I have a CT1900 I can help you to replace The U7 ROM.
By the way, I helped to repair a different soundcard previously: Orchid SoundWave 32 restoration
Reply 6 of 11, by Tiido
If you very carefully unshort the bond wires the EPROM should be usable still, I don't think I can see any broken wires on it.
Reply 7 of 11, by mt777
Thanks. Soon I will desolder ROM.
Currently I desolder damaged components from the CT1740 but the worst job will be fix broken traces at the bottom layer.
    873.28 KiB
    1.1 MiB
Reply 8 of 11, by root42
What happened to those cards? Did someone run them over with a car?
YouTube and Bonus
Reply 10 of 11, by mt777
I tried to desolder U7 rom using gun with electric pump but legs were very loose, shell also was broken and couldn't pull out it in one piece.
I thought that the second chip will be untouched but it was also broken (and circuit inside).
So @moturimi1 if you can dump them then please. I am not hurry with that.
