First post, by RodCastler
I hooked up an old AT hard drive to my PC via a USB dongle in the hopes of being able to hear the seek sounds of the drive while in Dosbox.
Since Dosbox caches the drive on startup, whenever I induce disk activity there is little to none interaction with the drive, hence no sounds coming from it (unless of course I copy files from one partition to another), but not when loading games or windows 3.1 for instance.
Is there any way to disable disk cache in order to emulate the real experience with the HDD?
Thank you
