First post, by cxm717
Okay, so I was interested in how these cards compare and decided to benchmark each in a few games. I thought I would share my results here.
The cards compared are a 16MB Creative TNT (CT6710), a Gainward 32MB TNT2 M64 and a Compaq 16MB TNT2 M64. Both TNT2 M64 cards were run at 125MHz/143MHz clocks.
I tested them on an Intel d815eea motherboard with 256MB PC133@CL2, a P3s@1.4GHz and a Creative sound blaster live. The drivers I used were det 2.08.
Some pics of the cards and setup: https://imgur.com/a/UK0rKa3
44.65 KiB
Edit: Added pics
Reply 1 of 12, by clueless1
Very cool, thanks for posting this! From a playability standpoint, there's not much difference between the three. I'm kind of surprised the 16MB TNT2 outscores the 32MB version as often as it does.
Reply 3 of 12, by cxm717
I ended up testing a few other cards in the system, to see how they compare with the M64 also. The cards I compared it with are a Matrox G450 32MB AGP and a Rage128GL 16MB AGP. The G450 is clocked at 120/150 MHz, somewhat lower than I have seen with other G450 cards. I figured it would be close to the M64 as it's the slowest Matrox G4x0 card, especially with these clocks.
here are the results:
43.48 KiB
Reply 4 of 12, by mwdmeyer
Awesome thanks for this! I remember hearing the M64 was similar to the OG TNT but it is good to know.
M64 got a lot of hate but isn't bad if the resolution is low.
Reply 5 of 12, by vvbee
Vs the geforce 4 ti4200: https://www.youtube.com/watch?v=CNFDYFBNd-4
Overclocked at 640 x 480 in rally trophy (2001): high details: https://www.youtube.com/watch?v=tUkFi3OxXto, low details: https://www.youtube.com/watch?v=fhj37jnZdH4.
The capture's a bit crap, but the low details rally trophy one looks retro as.
Reply 6 of 12, by Ozzuneoj
Thanks for doing these tests! This is great stuff! I think I'm actually going to bookmark your recent benchmark posts for future reference. 😀
Reply 7 of 12, by Almoststew1990
There is also an Anandtech review which compares the M64 to the proper TNT2.
https://www.anandtech.com/show/393
Reply 8 of 12, by appiah4
I just stumbled across this post while doing a Google search and wanted to thank the OP for it, amazingly informative. I was dumbfounded to see the original TNT performing close to a G450 at 16bit, but at 32bit at least the gap becomes meaningful.
Reply 9 of 12, by cxm717
Thanks.
Yeah the G450 is a bit odd, I think. It ends up being slower than you might expect just looking at the specs of the card (compared to the other G400 cards). In Quake2 at 640x480x16 the G400Max is 50% faster than the G450. I'll post the graphs with the G400Max later.
Reply 10 of 12, by cxm717
I actually did a comparison with a reg TNT2 (125/150) that I was going to post in this thread but forgot. So here it is:
112.1 KiB
The results here for the M64 cards was all retested. I mainly did that to make sure my original results were correct.
Reply 11 of 12, by lost77
Thanks for the benchmarks.
I replaced a TNT for a TNT2 M64 32MB back in 1999. This was mostly to get the extra RAM.
Seeing these benchmarks the upgrade only made sense at settings that I would consider unplayable.Maybe less micro-stuttering in some games with 32MB.
Good thing I got it for free.
