2 noob questions
First post, by DosboxNoob
i just started DosBox for the first time today
it looks so cool, finaly a program that can run The Horde for me :p
but i have 2 questions:
1) everytime i start DosBox i have to do "mount c c:\horde", isn't there a way it does that automaticly every time it starts? it's kinda anoying while testing that you have to type it each time
2) The Horde finaly works, but it runs kinda slow... unplayable slow...
what can i do about it? i mean, if it can run on a pc from 1993 with a normal speed, it should also work here :p
Reply 1 of 2, by canadacow
Both of your questions are answered in detail in the readme. There is additional help here: How to speed up DOSBox (by robertmo and mirekluza)
The quick answer to your first question though is to simply specify the path as a parameter when you run DosBox, for example, dosbox c:\horde
Reply 2 of 2, by Predator
close?
Don't be so hard
