First post, by tcs6382
Hi. I have been using DOSBOX with a program that configures industrial controllers. I have the program working perfectly communicating at 9600 baud with a controller. The only problem I have is part of the program uses two directories . The main directory contains the exe file and two directories called HLP which contains the help files and a directory called BLK which contains all the building blocks for the controller. The program has an error that it cannot find the blocks in folder. And also the help files say they are missing. The program will work on Windows XP and finds the help files but the computer runs to fast for the communications. I have the directory in th C: drive. Any help would be greatly appreciated
