First post, by Almoststew1990
- Oldbie
I have an MSI MS-6119 with a 440BX chipset. The website states that, if it has a blue sticker with a "c" on it on the Winbond chip, it will support coppermine (once on the latest bios). Mine doesn't have the sticker. However, it came with "a P3 CPU" and it turns out this is a 650MHz coppermine, which works. It is reported in the BIOS as a 650E, although according to the Wikipedia list of P3 Coppermine CPUs, this doesn't appear to exist. It's a SL3XK, which appears under the standard coppermine 650MHz in the table.
Does this mean my board will support all 100MHz FSB Coppermine CPUs? Can I stick a 800 - 900MHz in there?
