First post, by renojimmy
I'm not sure exactly what these are commonly known as, but does anyone know where I can buy a new/used LCD case display for this AT case?
It's 33mm wide, but might require some glue instead of screws to fit in 🤣
Reply 1 of 2, by deleted_nk
Not to my knowledge, the only real way you can get a speed display new nowadays is to get creative and make one yourself from an arduino or something similar. From time to time used displays from cases pop up on the likes of ebay which you could try and adapt to fit.
Reply 2 of 2, by treeman
I was looking around a while ago and also couldn't find any. however I saw a website how a guy made one using a led display which you can get for a few bux on ebay
check this out
http://oldcomputer.info/hacks/ledhilo/index.htm
