First post, by milpool
Hi everyone,
i have just patched Reality Adlib Tracker 1.1a to make use of the OPL2LPT on Lpt1 (0x3bc), and it's working fine, BUT: The effects are completely out of timing. Slide effects make some notes not play at all, or at a wrong pitch. Tunes which don't use effects play perfectly.
I have also compiled the stand alone player routine and everything is alright, so i guess it has to be the tracker which glitches on my machine. It's an IBM PS/2 Model L40SH (386sx/20), so maybe that machine is simply to slow to get the timing of the tracker and the player right at the same time?
Edit: Okay, i got it working now 🤣 It was a bit tricky, because the adlib routine did a bit more than just updating the adlib registers..
Anyway, i have the player and the tracker attached.
Reply 1 of 1, by BloodyCactus
since they just released Reality Adlib Tracker 2.0 you could just ask the author to do it for you... He is working on a 2.1 update so get int touch with him. well.... I dont know if 2.0 is a DOS or purely windows thing anymore but you could try asking him.
https://www.3eality.com/productions/reality-adlib-tracker
