Baoran wrote:No on board audio. Just empty spot on the motherboard where it could be in some motherboard versions.
Edit: I found a picture of it on my computer so I must have posted it in some other thread too.
Ok, so I am going to take a look at the datasheet for the southbridge. I wonder if DDMA support is disabled by default and there need to be a utility made to change a chipset register setting to get it to work.
Edit: Ok, so according to page 61 of the datasheet, DDMA is disabled by default.... and if the BIOS doesn't enable it, then that would explain why it isn't working.
The attachment VT82C686A SB datasheet rev 1.8.pdf is no longer available
So I am going to look into making a utility that can change the register settings to enable it and see if that works. Since I have a board with the 586b chipset that seems to also have the issue, I should be able to test on that. If it works, then that should not only help the YMF based cards but other cards that use DDMA.
