First post, by buckeye
Just noticed this when the trains go by in a scene everything slows to a crawl. My XP rig (see my sig) should have enough muscle for this game, is this a bug and if so is there a patch for it?
Intel SE440BX P3 450 256MB 80GB SSD Asus V7700 GF2 64mb SB 32pnp 350W 98SE
Reply 1 of 4, by Kerr Avon
Sorry, I can't help, but I do know that over the years Valve have improved (or at least altered) Half-Life 2's program and data, so perhaps you're using a newer version of the game, that needs more resources than your PC has?
Reply 2 of 4, by odey123
Yeh, if its not a version problem then possibly a settings problem? you are correct your hardware as far as i can tell should be able to slay this game. Vsync? what monitor is being used? what refresh rate? programs in the background?
Reply 3 of 4, by Fusion
I have a version of HL2 from 2004 that runs like a dream on my A64 3800+/2GB DDR RAM/ X800XT PE 256MB @ 575/575 @ 1080p max settings. No stuttering just the odd dip to the high 30s when in a busy area. Newer versions added a lot to the engine that will kill performance on older cards of the era.
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 207/207 - SB Live! 5.1 - Windows ME
Reply 4 of 4, by leileilol
The original 2004 build did have a lot of sound cache related stutter though...
