First post, by superfury
When I try to run Jazz Jackrabbit within UniPCemu, it tries to load a segment (0217) from user mode(segment E7) at instruction 00E7:0DBE into ES. This points to a segment descriptor containing F405.F405.54.7A.00.54 (seperated byte/word quantities with dots for readability, in unencoded little-endian order, so F405 is actually 5F4 when read as little endian 16-bits).
So, it's trying to load a segment with:
base: 545405F4
limit: 5F4
access rights: 7A(non-present code segment(non-conforming, readable, not accessed)).
Looking upwards, I see said value being written during a REPeated instruction? Perhaps a memory move/memcpy?
Search from the bottom of the log for "00:27:37:59.03216: #NP fault(00000214)!" (without quotes) for the point the program reaches the exception and aborts.
Looking a bit further up, I see ES being loaded with 2f03.303b.13.f3.00.00, so a plain data segment(accessed), at Privilege level 3, base address 133b30, limit 32f. Said descriptor is at 11b300?
Interestingly, the descriptor it's trying to load into ES is located at 0011b400, exactly 100h bytes AFTER the descriptor that was previously loaded into ES?
I see said descriptor access rights being written at:
0020:000007fb F3 A5 rep movsw Paged(w):0011b400=f4(?); Physical(w):0011b400=f4(?); RAM(w):0011b400=f4(?); RealRAM(w):000bb400=f4(?); Paged(w):0011b401=05(); Physical(w):0011b401=05(); RAM(w):0011b401=05(); RealRAM(w):000bb401=05()Registers:EAX: 60000210 EBX: 00000217 ECX: 00000004 EDX: 00000170ESP: 00000f90 EBP: 00000f9a ESI: 00000392 EDI: 00000210CS: 0020 DS: 009f ES: 0170 FS: 0000 GS: 0000 SS: 0018 TR: 0158 LDTR: 0168EIP: 000007fb EFLAGS: 00003006CR0: 60000011 CR1: 00000000 CR2: 00000000 CR3: 00000000CR4: 00000000DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000DR6: 00000000 DR7: 00000000GDTR: 00000001180003ff IDTR: 000000117df007ffFLAGSINFO: 0000000000i00avr0n11oditsz0a0P1cRealRAM(p):000b17fb=f3(?); RAM(p):001117fb=f3(?); Physical(p):001117fb=f3(?); Paged(p):001117fb=f3(?); Normal(p):000007fb=f3(?); RealRAM(p):000b17fc=a5(?); RAM(p):001117fc=a5(?); Physical(p):001117fc=a5(?); Paged(p):001117fc=a5(?); Normal(p):000007fc=a5(?); RealRAM(p):000b17fd=59(Y); RAM(p):001117fd=59(Y); Physical(p):001117fd=59(Y); Paged(p):001117fd=59(Y); Normal(p):000007fd=59(Y); RealRAM(p):000b17fe=5e(^); RAM(p):001117fe=5e(^); Physical(p):001117fe=5e(^); Paged(p):001117fe=5e(^); Normal(p):000007fe=5e(^); RealRAM(p):000b17ff=1f(); RAM(p):001117ff=1f(); Physical(p):001117ff=1f(); Paged(p):001117ff=1f(); Normal(p):000007ff=1f(); RealRAM(p):000b1800=5f(_); RAM(p):00111800=5f(_); Physical(p):00111800=5f(_); Paged(p):00111800=5f(_); Normal(p):00000800=5f(_); RealRAM(p):000b1801=07(); RAM(p):00111801=07(); Physical(p):00111801=07(); Paged(p):00111801=07(); Normal(p):00000801=07(); RealRAM(p):000b1802=c9(?); RAM(p):00111802=c9(?); Physical(p):00111802=c9(?); Paged(p):00111802=c9(?); Normal(p):00000802=c9(?); RealRAM(p):000b1803=c3(?); RAM(p):00111803=c3(?); Physical(p):00111803=c3(?); Paged(p):00111803=c3(?); Normal(p):00000803=c3(?); RealRAM(p):000b1804=c8(?); RAM(p):00111804=c8(?); Physical(p):00111804=c8(?); Paged(p):00111804=c8(?); Normal(p):00000804=c8(?); RealRAM(p):000b1805=00( ); RAM(p):00111805=00( ); Physical(p):00111805=00( ); Paged(p):00111805=00( ); Normal(p):00000805=00( ); RealRAM(p):000b1806=00( ); RAM(p):00111806=00( ); Physical(p):00111806=00( ); Paged(p):00111806=00( ); Normal(p):00000806=00( ); RealRAM(p):000b1807=00( ); RAM(p):00111807=00( ); Physical(p):00111807=00( ); Paged(p):00111807=00( ); Normal(p):00000807=00( ); RealRAM(p):000b1808=8b(?); RAM(p):00111808=8b(?); Physical(p):00111808=8b(?); Paged(p):00111808=8b(?); Normal(p):00000808=8b(?); RealRAM(p):000b1809=46(F); RAM(p):00111809=46(F); Physical(p):00111809=46(F); Paged(p):00111809=46(F); Normal(p):00000809=46(F); RealRAM(p):000b180a=04(); RAM(p):0011180a=04(); Physical(p):0011180a=04(); Paged(p):0011180a=04(); Normal(p):0000080a=04(); RealRAM(p):000b180b=a9(?); RAM(p):0011180b=a9(?); Physical(p):0011180b=a9(?); Paged(p):0011180b=a9(?); Normal(p):0000080b=a9(?); RealRAM(p):000b180c=04(); RAM(p):0011180c=04(); Physical(p):0011180c=04(); Paged(p):0011180c=04(); Normal(p):0000080c=04(); RealRAM(p):000b180d=00( ); RAM(p):0011180d=00( ); Physical(p):0011180d=00( ); Paged(p):0011180d=00( ); Normal(p):0000080d=00( ); RealRAM(p):000b180e=74(t); RAM(p):0011180e=74(t); Physical(p):0011180e=74(t); Paged(p):0011180e=74(t); Normal(p):0000080e=74(t); RealRAM(p):000b180f=08(); RAM(p):0011180f=08(); Physical(p):0011180f=08(); Paged(p):0011180f=08(); Normal(p):0000080f=08(); RealRAM(p):000b1810=0f(); RAM(p):00111810=0f(); Physical(p):00111810=0f(); Paged(p):00111810=0f(); Normal(p):00000810=0f(); RealRAM(p):000b1811=00( ); RAM(p):00111811=00( ); Physical(p):00111811=00( ); Paged(p):00111811=00( ); Normal(p):00000811=00( ); RealRAM(p):000b1812=c2(?); RAM(p):00111812=c2(?); Physical(p):00111812=c2(?); Paged(p):00111812=c2(?); Normal(p):00000812=c2(?); RealRAM(p):000b1813=83(?); RAM(p):00111813=83(?); Physical(p):00111813=83(?); Paged(p):00111813=83(?); Normal(p):00000813=83(?); RealRAM(p):000b1814=c2(?); RAM(p):00111814=c2(?); Physical(p):00111814=c2(?); Paged(p):00111814=c2(?); Normal(p):00000814=c2(?); RealRAM(p):000b1815=08(); RAM(p):00111815=08(); Physical(p):00111815=08(); Paged(p):00111815=08(); Normal(p):00000815=08(); RealRAM(p):000b1816=eb(?); RAM(p):00111816=eb(?); Physical(p):00111816=eb(?); Paged(p):00111816=eb(?); Normal(p):00000816=eb(?); RealRAM(p):000b1817=03(); RAM(p):00111817=03(); Physical(p):00111817=03(); Paged(p):00111817=03(); Normal(p):00000817=03(); RealRAM(p):000b1818=ba(?); RAM(p):00111818=ba(?); Physical(p):00111818=ba(?); Paged(p):00111818=ba(?); Normal(p):00000818=ba(?); RealRAM(p):000b1819=10(); RAM(p):00111819=10(); Physical(p):00111819=10(); Paged(p):00111819=10(); Normal(p):00000819=10(); RealRAM(p):000b181a=00( ); RAM(p):0011181a=00( ); Physical(p):0011181a=00( ); Paged(p):0011181a=00( ); Normal(p):0000081a=00( ); RealRAM(r):00017804=f4(?); RAM(r):00017804=f4(?); Physical(r):00017804=f4(?); Paged(r):00017804=f4(?); RealRAM(r):00017805=05(); RAM(r):00017805=05(); Physical(r):00017805=05(); Paged(r):00017805=05()Paged(w):0011b402=f4(?); Physical(w):0011b402=f4(?); RAM(w):0011b402=f4(?); RealRAM(w):000bb402=f4(?); Paged(w):0011b403=05(); Physical(w):0011b403=05(); RAM(w):0011b403=05(); RealRAM(w):000bb403=05(); RealRAM(p):000b17fb=f3(?); RAM(p):001117fb=f3(?); Physical(p):001117fb=f3(?); Paged(p):001117fb=f3(?); Normal(p):000007fb=f3(?); RealRAM(p):000b17fc=a5(?); RAM(p):001117fc=a5(?); Physical(p):001117fc=a5(?); Paged(p):001117fc=a5(?); Normal(p):000007fc=a5(?); RealRAM(p):000b17fd=59(Y); RAM(p):001117fd=59(Y); Physical(p):001117fd=59(Y); Paged(p):001117fd=59(Y); Normal(p):000007fd=59(Y); RealRAM(p):000b17fe=5e(^); RAM(p):001117fe=5e(^); Physical(p):001117fe=5e(^); Paged(p):001117fe=5e(^); Normal(p):000007fe=5e(^); RealRAM(p):000b17ff=1f(); RAM(p):001117ff=1f(); Physical(p):001117ff=1f(); Paged(p):001117ff=1f(); Normal(p):000007ff=1f(); RealRAM(p):000b1800=5f(_); RAM(p):00111800=5f(_); Physical(p):00111800=5f(_); Paged(p):00111800=5f(_); Normal(p):00000800=5f(_); RealRAM(p):000b1801=07(); RAM(p):00111801=07(); Physical(p):00111801=07(); Paged(p):00111801=07(); Normal(p):00000801=07(); RealRAM(p):000b1802=c9(?); RAM(p):00111802=c9(?); Physical(p):00111802=c9(?); Paged(p):00111802=c9(?); Normal(p):00000802=c9(?); RealRAM(p):000b1803=c3(?); RAM(p):00111803=c3(?); Physical(p):00111803=c3(?); Paged(p):00111803=c3(?); Normal(p):00000803=c3(?); RealRAM(p):000b1804=c8(?); RAM(p):00111804=c8(?); Physical(p):00111804=c8(?); Paged(p):00111804=c8(?); Normal(p):00000804=c8(?); RealRAM(p):000b1805=00( ); RAM(p):00111805=00( ); Physical(p):00111805=00( ); Paged(p):00111805=00( ); Normal(p):00000805=00( ); RealRAM(p):000b1806=00( ); RAM(p):00111806=00( ); Physical(p):00111806=00( ); Paged(p):00111806=00( ); Normal(p):00000806=00( ); RealRAM(p):000b1807=00( ); RAM(p):00111807=00( ); Physical(p):00111807=00( ); Paged(p):00111807=00( ); Normal(p):00000807=00( ); RealRAM(p):000b1808=8b(?); RAM(p):00111808=8b(?); Physical(p):00111808=8b(?); Paged(p):00111808=8b(?); Normal(p):00000808=8b(?); RealRAM(p):000b1809=46(F); RAM(p):00111809=46(F); Physical(p):00111809=46(F); Paged(p):00111809=46(F); Normal(p):00000809=46(F); RealRAM(p):000b180a=04(); RAM(p):0011180a=04(); Physical(p):0011180a=04(); Paged(p):0011180a=04(); Normal(p):0000080a=04(); RealRAM(p):000b180b=a9(?); RAM(p):0011180b=a9(?); Physical(p):0011180b=a9(?); Paged(p):0011180b=a9(?); Normal(p):0000080b=a9(?); RealRAM(p):000b180c=04(); RAM(p):0011180c=04(); Physical(p):0011180c=04(); Paged(p):0011180c=04(); Normal(p):0000080c=04(); RealRAM(p):000b180d=00( ); RAM(p):0011180d=00( ); Physical(p):0011180d=00( ); Paged(p):0011180d=00( ); Normal(p):0000080d=00( ); RealRAM(p):000b180e=74(t); RAM(p):0011180e=74(t); Physical(p):0011180e=74(t); Paged(p):0011180e=74(t); Normal(p):0000080e=74(t); RealRAM(p):000b180f=08(); RAM(p):0011180f=08(); Physical(p):0011180f=08(); Paged(p):0011180f=08(); Normal(p):0000080f=08(); RealRAM(p):000b1810=0f(); RAM(p):00111810=0f(); Physical(p):00111810=0f(); Paged(p):00111810=0f(); Normal(p):00000810=0f(); RealRAM(p):000b1811=00( ); RAM(p):00111811=00( ); Physical(p):00111811=00( ); Paged(p):00111811=00( ); Normal(p):00000811=00( ); RealRAM(p):000b1812=c2(?); RAM(p):00111812=c2(?); Physical(p):00111812=c2(?); Paged(p):00111812=c2(?); Normal(p):00000812=c2(?); RealRAM(p):000b1813=83(?); RAM(p):00111813=83(?); Physical(p):00111813=83(?); Paged(p):00111813=83(?); Normal(p):00000813=83(?); RealRAM(p):000b1814=c2(?); RAM(p):00111814=c2(?); Physical(p):00111814=c2(?); Paged(p):00111814=c2(?); Normal(p):00000814=c2(?); RealRAM(p):000b1815=08(); RAM(p):00111815=08(); Physical(p):00111815=08(); Paged(p):00111815=08(); Normal(p):00000815=08(); RealRAM(p):000b1816=eb(?); RAM(p):00111816=eb(?); Physical(p):00111816=eb(?); Paged(p):00111816=eb(?); Normal(p):00000816=eb(?); RealRAM(p):000b1817=03(); RAM(p):00111817=03(); Physical(p):00111817=03(); Paged(p):00111817=03(); Normal(p):00000817=03(); RealRAM(p):000b1818=ba(?); RAM(p):00111818=ba(?); Physical(p):00111818=ba(?); Paged(p):00111818=ba(?); Normal(p):00000818=ba(?); RealRAM(p):000b1819=10(); RAM(p):00111819=10(); Physical(p):00111819=10(); Paged(p):00111819=10(); Normal(p):00000819=10(); RealRAM(p):000b181a=00( ); RAM(p):0011181a=00( ); Physical(p):0011181a=00( ); Paged(p):0011181a=00( ); Normal(p):0000081a=00( ); RealRAM(r):00017806=54(T); RAM(r):00017806=54(T); Physical(r):00017806=54(T); Paged(r):00017806=54(T); RealRAM(r):00017807=7a(z); RAM(r):00017807=7a(z); Physical(r):00017807=7a(z); Paged(r):00017807=7a(z)Paged(w):0011b404=54(T); Physical(w):0011b404=54(T); RAM(w):0011b404=54(T); RealRAM(w):000bb404=54(T); Paged(w):0011b405=7a(z); Physical(w):0011b405=7a(z); RAM(w):0011b405=7a(z); RealRAM(w):000bb405=7a(z); RealRAM(p):000b17fb=f3(?); RAM(p):001117fb=f3(?); Physical(p):001117fb=f3(?); Paged(p):001117fb=f3(?); Normal(p):000007fb=f3(?); RealRAM(p):000b17fc=a5(?); RAM(p):001117fc=a5(?); Physical(p):001117fc=a5(?); Paged(p):001117fc=a5(?); Normal(p):000007fc=a5(?); RealRAM(p):000b17fd=59(Y); RAM(p):001117fd=59(Y); Physical(p):001117fd=59(Y); Paged(p):001117fd=59(Y); Normal(p):000007fd=59(Y); RealRAM(p):000b17fe=5e(^); RAM(p):001117fe=5e(^); Physical(p):001117fe=5e(^); Paged(p):001117fe=5e(^); Normal(p):000007fe=5e(^); RealRAM(p):000b17ff=1f(); RAM(p):001117ff=1f(); Physical(p):001117ff=1f(); Paged(p):001117ff=1f(); Normal(p):000007ff=1f(); RealRAM(p):000b1800=5f(_); RAM(p):00111800=5f(_); Physical(p):00111800=5f(_); Paged(p):00111800=5f(_); Normal(p):00000800=5f(_); RealRAM(p):000b1801=07(); RAM(p):00111801=07(); Physical(p):00111801=07(); Paged(p):00111801=07(); Normal(p):00000801=07(); RealRAM(p):000b1802=c9(?); RAM(p):00111802=c9(?); Physical(p):00111802=c9(?); Paged(p):00111802=c9(?); Normal(p):00000802=c9(?); RealRAM(p):000b1803=c3(?); RAM(p):00111803=c3(?); Physical(p):00111803=c3(?); Paged(p):00111803=c3(?); Normal(p):00000803=c3(?); RealRAM(p):000b1804=c8(?); RAM(p):00111804=c8(?); Physical(p):00111804=c8(?); Paged(p):00111804=c8(?); Normal(p):00000804=c8(?); RealRAM(p):000b1805=00( ); RAM(p):00111805=00( ); Physical(p):00111805=00( ); Paged(p):00111805=00( ); Normal(p):00000805=00( ); RealRAM(p):000b1806=00( ); RAM(p):00111806=00( ); Physical(p):00111806=00( ); Paged(p):00111806=00( ); Normal(p):00000806=00( ); RealRAM(p):000b1807=00( ); RAM(p):00111807=00( ); Physical(p):00111807=00( ); Paged(p):00111807=00( ); Normal(p):00000807=00( ); RealRAM(p):000b1808=8b(?); RAM(p):00111808=8b(?); Physical(p):00111808=8b(?); Paged(p):00111808=8b(?); Normal(p):00000808=8b(?); RealRAM(p):000b1809=46(F); RAM(p):00111809=46(F); Physical(p):00111809=46(F); Paged(p):00111809=46(F); Normal(p):00000809=46(F); RealRAM(p):000b180a=04(); RAM(p):0011180a=04(); Physical(p):0011180a=04(); Paged(p):0011180a=04(); Normal(p):0000080a=04(); RealRAM(p):000b180b=a9(?); RAM(p):0011180b=a9(?); Physical(p):0011180b=a9(?); Paged(p):0011180b=a9(?); Normal(p):0000080b=a9(?); RealRAM(p):000b180c=04(); RAM(p):0011180c=04(); Physical(p):0011180c=04(); Paged(p):0011180c=04(); Normal(p):0000080c=04(); RealRAM(p):000b180d=00( ); RAM(p):0011180d=00( ); Physical(p):0011180d=00( ); Paged(p):0011180d=00( ); Normal(p):0000080d=00( ); RealRAM(p):000b180e=74(t); RAM(p):0011180e=74(t); Physical(p):0011180e=74(t); Paged(p):0011180e=74(t); Normal(p):0000080e=74(t); RealRAM(p):000b180f=08(); RAM(p):0011180f=08(); Physical(p):0011180f=08(); Paged(p):0011180f=08(); Normal(p):0000080f=08(); RealRAM(p):000b1810=0f(); RAM(p):00111810=0f(); Physical(p):00111810=0f(); Paged(p):00111810=0f(); Normal(p):00000810=0f(); RealRAM(p):000b1811=00( ); RAM(p):00111811=00( ); Physical(p):00111811=00( ); Paged(p):00111811=00( ); Normal(p):00000811=00( ); RealRAM(p):000b1812=c2(?); RAM(p):00111812=c2(?); Physical(p):00111812=c2(?); Paged(p):00111812=c2(?); Normal(p):00000812=c2(?); RealRAM(p):000b1813=83(?); RAM(p):00111813=83(?); Physical(p):00111813=83(?); Paged(p):00111813=83(?); Normal(p):00000813=83(?); RealRAM(p):000b1814=c2(?); RAM(p):00111814=c2(?); Physical(p):00111814=c2(?); Paged(p):00111814=c2(?); Normal(p):00000814=c2(?); RealRAM(p):000b1815=08(); RAM(p):00111815=08(); Physical(p):00111815=08(); Paged(p):00111815=08(); Normal(p):00000815=08(); RealRAM(p):000b1816=eb(?); RAM(p):00111816=eb(?); Physical(p):00111816=eb(?); Paged(p):00111816=eb(?); Normal(p):00000816=eb(?); RealRAM(p):000b1817=03(); RAM(p):00111817=03(); Physical(p):00111817=03(); Paged(p):00111817=03(); Normal(p):00000817=03(); RealRAM(p):000b1818=ba(?); RAM(p):00111818=ba(?); Physical(p):00111818=ba(?); Paged(p):00111818=ba(?); Normal(p):00000818=ba(?); RealRAM(p):000b1819=10(); RAM(p):00111819=10(); Physical(p):00111819=10(); Paged(p):00111819=10(); Normal(p):00000819=10(); RealRAM(p):000b181a=00( ); RAM(p):0011181a=00( ); Physical(p):0011181a=00( ); Paged(p):0011181a=00( ); Normal(p):0000081a=00( ); RealRAM(r):00017808=00( ); RAM(r):00017808=00( ); Physical(r):00017808=00( ); Paged(r):00017808=00( ); RealRAM(r):00017809=54(T); RAM(r):00017809=54(T); Physical(r):00017809=54(T); Paged(r):00017809=54(T)Paged(w):0011b406=00( ); Physical(w):0011b406=00( ); RAM(w):0011b406=00( ); RealRAM(w):000bb406=00( ); Paged(w):0011b407=54(T); Physical(w):0011b407=54(T); RAM(w):0011b407=54(T); RealRAM(w):000bb407=54(T); RealRAM(p):000b17fb=f3(?); RAM(p):001117fb=f3(?); Physical(p):001117fb=f3(?); Paged(p):001117fb=f3(?); Normal(p):000007fb=f3(?); RealRAM(p):000b17fc=a5(?); RAM(p):001117fc=a5(?); Physical(p):001117fc=a5(?); Paged(p):001117fc=a5(?); Normal(p):000007fc=a5(?); RealRAM(p):000b17fd=59(Y); RAM(p):001117fd=59(Y); Physical(p):001117fd=59(Y); Paged(p):001117fd=59(Y); Normal(p):000007fd=59(Y); RealRAM(p):000b17fe=5e(^); RAM(p):001117fe=5e(^); Physical(p):001117fe=5e(^); Paged(p):001117fe=5e(^); Normal(p):000007fe=5e(^); RealRAM(p):000b17ff=1f(); RAM(p):001117ff=1f(); Physical(p):001117ff=1f(); Paged(p):001117ff=1f(); Normal(p):000007ff=1f(); RealRAM(p):000b1800=5f(_); RAM(p):00111800=5f(_); Physical(p):00111800=5f(_); Paged(p):00111800=5f(_); Normal(p):00000800=5f(_); RealRAM(p):000b1801=07(); RAM(p):00111801=07(); Physical(p):00111801=07(); Paged(p):00111801=07(); Normal(p):00000801=07(); RealRAM(p):000b1802=c9(?); RAM(p):00111802=c9(?); Physical(p):00111802=c9(?); Paged(p):00111802=c9(?); Normal(p):00000802=c9(?); RealRAM(p):000b1803=c3(?); RAM(p):00111803=c3(?); Physical(p):00111803=c3(?); Paged(p):00111803=c3(?); Normal(p):00000803=c3(?); RealRAM(p):000b1804=c8(?); RAM(p):00111804=c8(?); Physical(p):00111804=c8(?); Paged(p):00111804=c8(?); Normal(p):00000804=c8(?); RealRAM(p):000b1805=00( ); RAM(p):00111805=00( ); Physical(p):00111805=00( ); Paged(p):00111805=00( ); Normal(p):00000805=00( ); RealRAM(p):000b1806=00( ); RAM(p):00111806=00( ); Physical(p):00111806=00( ); Paged(p):00111806=00( ); Normal(p):00000806=00( ); RealRAM(p):000b1807=00( ); RAM(p):00111807=00( ); Physical(p):00111807=00( ); Paged(p):00111807=00( ); Normal(p):00000807=00( ); RealRAM(p):000b1808=8b(?); RAM(p):00111808=8b(?); Physical(p):00111808=8b(?); Paged(p):00111808=8b(?); Normal(p):00000808=8b(?); RealRAM(p):000b1809=46(F); RAM(p):00111809=46(F); Physical(p):00111809=46(F); Paged(p):00111809=46(F); Normal(p):00000809=46(F); RealRAM(p):000b180a=04(); RAM(p):0011180a=04(); Physical(p):0011180a=04(); Paged(p):0011180a=04(); Normal(p):0000080a=04(); RealRAM(p):000b180b=a9(?); RAM(p):0011180b=a9(?); Physical(p):0011180b=a9(?); Paged(p):0011180b=a9(?); Normal(p):0000080b=a9(?); RealRAM(p):000b180c=04(); RAM(p):0011180c=04(); Physical(p):0011180c=04(); Paged(p):0011180c=04(); Normal(p):0000080c=04(); RealRAM(p):000b180d=00( ); RAM(p):0011180d=00( ); Physical(p):0011180d=00( ); Paged(p):0011180d=00( ); Normal(p):0000080d=00( ); RealRAM(p):000b180e=74(t); RAM(p):0011180e=74(t); Physical(p):0011180e=74(t); Paged(p):0011180e=74(t); Normal(p):0000080e=74(t); RealRAM(p):000b180f=08(); RAM(p):0011180f=08(); Physical(p):0011180f=08(); Paged(p):0011180f=08(); Normal(p):0000080f=08(); RealRAM(p):000b1810=0f(); RAM(p):00111810=0f(); Physical(p):00111810=0f(); Paged(p):00111810=0f(); Normal(p):00000810=0f(); RealRAM(p):000b1811=00( ); RAM(p):00111811=00( ); Physical(p):00111811=00( ); Paged(p):00111811=00( ); Normal(p):00000811=00( ); RealRAM(p):000b1812=c2(?); RAM(p):00111812=c2(?); Physical(p):00111812=c2(?); Paged(p):00111812=c2(?); Normal(p):00000812=c2(?); RealRAM(p):000b1813=83(?); RAM(p):00111813=83(?); Physical(p):00111813=83(?); Paged(p):00111813=83(?); Normal(p):00000813=83(?); RealRAM(p):000b1814=c2(?); RAM(p):00111814=c2(?); Physical(p):00111814=c2(?); Paged(p):00111814=c2(?); Normal(p):00000814=c2(?); RealRAM(p):000b1815=08(); RAM(p):00111815=08(); Physical(p):00111815=08(); Paged(p):00111815=08(); Normal(p):00000815=08(); RealRAM(p):000b1816=eb(?); RAM(p):00111816=eb(?); Physical(p):00111816=eb(?); Paged(p):00111816=eb(?); Normal(p):00000816=eb(?); RealRAM(p):000b1817=03(); RAM(p):00111817=03(); Physical(p):00111817=03(); Paged(p):00111817=03(); Normal(p):00000817=03(); RealRAM(p):000b1818=ba(?); RAM(p):00111818=ba(?); Physical(p):00111818=ba(?); Paged(p):00111818=ba(?); Normal(p):00000818=ba(?); RealRAM(p):000b1819=10(); RAM(p):00111819=10(); Physical(p):00111819=10(); Paged(p):00111819=10(); Normal(p):00000819=10(); RealRAM(p):000b181a=00( ); RAM(p):0011181a=00( ); Physical(p):0011181a=00( ); Paged(p):0011181a=00( ); Normal(p):0000081a=00( ); RealRAM(p):000b181b=25(%); RAM(p):0011181b=25(%); Physical(p):0011181b=25(%); Paged(p):0011181b=25(%); Normal(p):0000081b=25(%); RealRAM(p):000b181c=f8(?); RAM(p):0011181c=f8(?); Physical(p):0011181c=f8(?); Paged(p):0011181c=f8(?); Normal(p):0000081c=f8(?)
UniPCemu Git repository
