First post, by SilverSurfer
1) use of Windows 10 64bits
2) trying to install old game/encyclopedia "JamesBond 007" from Eidos, under Windows 3.1 or Windows 95. To install with file Install.exe on cdrom.
3) in DosBox, given << Mount c i:\ -t cdrom >> and then c: - ok
4) entered << Install >> then DosBox displays << win Install.exe >> and doesnt move anymore
5) if I press then button [Enter] I receive << Illegal command : win. >>
Can you tell me how I can let install an old game under windows 10 64bits pls
Thank you
Reply 1 of 2, by DosFreak
DOSBox only runs DOS games. To run a Wndows game you need Windows.
DOSBox only supports Windows 3.x as a Windows guest so you'll need to install Windows 3.x inside DOSBox if you want to play this game.
Make your games work offline
Reply 2 of 2, by SilverSurfer
Thank you DosFreak, I'll try this.
SS
