First post, by Baoran
Basic isa 386 motherboard. I know I probably can't fix it, but if someone who has more technical information on how motherboards work could explain me what could theoretically be wrong with a motherboard that would cause floppy drives not working with the motherboard.
Ram is fine, motherboard cache has been disabled. I/O controller is a separate isa card that has 1.44Mb floppy drive and 120Mb hard drive connected to it and the card has been tested with these same floppy drive and hard drive on another motherboard and they work fine. I moved the card with same things connected to it directly from one motherboard to another. Hard drive and the floppy drive are recognized during post. Hard drive works fine and boots and I can run anything on the hard drive and programs work in dos. Floppy drive doesn't work and either directory listing shows empty even if there are files on the disk or it shows random characters mixed with the directory listing. Sometimes there are also general and invalid media errors.
What could be theoretically be broken on the motherboard that could cause something like this when the FDD controller is on a separate working isa card?
Reply 1 of 8, by bjwil1991
In the BIOS, do you have drive A: set to 1.44MB 3.5" under general settings? Is the activity light steady or does it turn on and goes back off during a floppy seek or directory listing?
Reply 2 of 8, by Baoran
I went through the motherboard one more time with a magnifier. I think I found something in the corner of the chipset. Not sure if that can be fixed, but I don't think I have anything so thin that I can try putting between those.
1.94 MiB
Reply 3 of 8, by bjwil1991
That's not good. A thin flat tipped screwdriver might help (carefully).
Reply 4 of 8, by Tiido
I use one of those razor knives in such cases, the blade is thin enough to nicely fit between the pins and you can then carefully bend them back to position.
Reply 5 of 8, by Mister Xiado
Yes, move extremely slowly, and juuust in case, clean the pins, dab a bit of flux on them, and tin them in case of any small fractures in the legs that aren't immediately apparent.
Reply 7 of 8, by Baoran
I think I failed. I managed to separate them and they look ok, but now floppy drive doesn't react to anything at all. Perhaps irq line is broken even though I can't see anything wrong with the ones that I separated.
Well, at least I tried to fix it and I was being as careful as possible.
Reply 8 of 8, by bjwil1991
Have you tried to clear the BIOS settings lately? In some cases, clearing the settings can help.
