First post, by brostenen
- l33t++
Hi all....
I am qurious on what solder tin people usually use, when soldering SMD and Hole-Through.
There is these two most commonly seen on the market, which are 63/37 and 60/40.
Usually I use 60/40 for all my solder work, though I really would like to know what people use.
Do people use 60/40 for both SMD and Hole-Through or the other or a combination?
Finally. What are people's personal experience with the two different alloy's when doing a specific solder work?
