First post, by Lo-ResBros
ok weird issue
I have a Sound Blaster 16 CT2230 and it works perfectly except one issue. When games like Phantasmagoria and 7th Guest are playing cut scenes off the cd-rom, I get a ticking noise in the background while the disc is being accessed. Almost in sync to the light as it flashes on the drive.
A220 I7 D1 H5 P330 T6
I’ve tried IRQ 5, and I’ve tried setting the High DMA to low (1), I’ve also tried another cdrom drive but I have no audio cable for that one yet. I still get the same ticking though
I have the cdrom audio cable connectedto the sound card and cd audio seems to play perfectly, for example the opening of 7th Guest with the title screen and lightning, music all plays perfectly, only when the following cut scenes start do I get the ticking as the drive is reading.
I even fully re-capped the sound card with quality capacitors. Any ideas?
note I’m playing with original cds, original hardware 486DX2-66, MSDOS 6.22
AMD K6-2+/550MHz
Soltek SL-54U5 Super Socket 7
64MB SDRAM
3DFX Voodoo 3 3000 16MB
Sound Blaster AWE64
Roland SC-55mkII
Pentium MMX 233MHz
Tyan TitanVX S1470 Socket 7
128MB SDRAM
ATi Rage 128 pro 32MB
Audio Plus 320 v.1
Roland SC-88
