First post, by Arbys Guy
subject explains it all, the site wont work for me. http://us.aopen.com/products_download.aspx?auno=725
if anybody has this or knows a link would be much appreciated (=
Reply 1 of 2, by Robert B
Here you go. I hope that these files are what you are looking for.
This is for the AX63 NON PRO version.
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-131.shtml
I attached the 1.31 AX63 BIOS I downloaded from the link, just in case.
On the same site you can also find other versions:
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-130.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-128.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-127.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-126.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-124.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-121.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-120.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-119.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-117.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-113.shtml
https://drivers.softpedia.com/get/BIOS/Aopen/ … -Bios-112.shtml
If you need the BIOS files for the AX63PRO you can find them also on softpedia.com
https://drivers.softpedia.com/dyn-search.php? … term=aopen+AX63
CHECK AND DOUBLE CHECK AND TRIPLE CHECK before you flash! If you have a BIOS programmer then you are safe as you can try more versions.
REMEMBER to check if your board is AX63 or AX63 PRO!
CHECK the BIOS FILE SIZES if they match the specs/size of the BIOS chip. For example for my GA-8TM there are two types of BIOS files 3Mb and 4Mb.
Good luck!
Reply 2 of 2, by Arbys Guy
Sweet thank you!!!
yes it is the AX63 i triple checked, searched the pro board up and it says pro on the mobo mine sadly does not )=.
i swear i only got 2 pages on google 🤣. and most links were for the pro.
