small electronic fix
First post, by mrau
hello,
if i have very bad unstable mains (huge amount of spikes, some over 4kv) and want to protect my little retro project - does it make sense to turn all three wires in the mains cable around a separate ferromagnetic torus or is it this not better than choking just the phase wire?
Reply 1 of 7, by cyclone3d
I would get a Line Interactive UPS that runs the inverter all the time. That will give you about the best line conditioning you can get.
Voltage spikes are no laughing matter when it comes to electronics.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 7, by mrau
thanks for replying so fast
line interactive is that type which catches all anomalies, right? i was looking at apc pro 900 a few days ago - it was about half the required total power, but the price - just awful
i'm looking into cheaper alternatives that i can first test on my contemporary hardware
Reply 3 of 7, by wiretap
First, call your power company to fix that.. It's unsafe for one, and it can damage anything plugged in. Second, I would run an isolation transformer with an AVR UPS behind it.
My Github
Circuit Board Repair Manuals
Reply 4 of 7, by gdjacobs
Indeed, that's extremely unsafe. Line voltage should typically be +/- 5%. Multi kV range transients could begin tracking across and degrading the insulation of your household electrical system.
Reply 5 of 7, by Cyberdyne
You need an online ups, not a line interactive. Online ups makes it own sinus all the time, line interactive only makes one, when input fails.
Reply 6 of 7, by GigAHerZ
Cyberdyne, you mean that backup ups kicks in only when input fails? Line interactive one is turned on all the time, correcting the voltage. (Though, its not creating the whole output power from scratch)
https://www.youtube.com/watch?v=Fj7e3WGUKO8
A little about software engineering: https://byteaether.github.io/
Reply 7 of 7, by gdjacobs
Double conversion vs line interactive.
