First post, by WebDrake
Hello,
I'm running DosBox 0.61 on my laptop and I have problems with fullscreen mode. When I press ALT+ENTER to go into fullscreen, the system tries to go into fullscreen for a second or two (the screen goes black) and then jumps back to the previous display, except that the small dosbox window is now in the top right-hand corner of the display instead of in the centre.
Sometimes I get an error message as follows:
- You have selected a non-optimal Screen Area setting for your LCD panel. Unlike external computer monitors, LCD panels have one particular Screen Area setting that looks best. It is recommended you set your Screen Area to 1920x1200.
I've tried modifying the fullwidth and fullheight keys in the .conf file to these settings, but that doesn't seem to change anything. Any advice?
My setup is DosBox 0.61 running a Dell Inspiron 8600 with Windows XP Pro, Service Pack 2, with a Pentium M 1.7 GHz processor. The graphics card is an ATI Mobility Radeon 9600 Pro Turbo with 128Mb RAM; the LCD display is 1920x1200.
Many thanks,
-- Joe
