First post, by iraito
- Oldbie
I'm finally almost finished with one of my retro rigs (athlon XP\9800XXL\1 DDR\Audigy 2 ZS) which i have been working on since early autumn, most of my time has been spent into cable management, fan positioning, setting up a voltage regulator for the case fans and modding the case, boy was this case insanely hot before adding the current fans (1 intake 80mm on the side panel blowing on the backplate of the GPU, the northbridge and CPU, 1 120mm intake on the upper front of the case occupying the space of the drive bay faceplates and 1 80mm exhaust on the upper back) the back of the 9800XXL was too hot to touch after 30 minutes, now it gets just warm and the case gets just barely warm.
Now, i still have 2 fans available (1 90mm and 1 80mm) and i was thinking of adding the last fan to eliminate the warm air accumulating in the lower back part of the case (in-between the soundblaster and the radeon) since i'm scared of how summer could make the case a little too hot for my tastes, so i was thinking of adding the 80mm fan in between the GPU and the audio card to either add cold air or eliminate the hot one, the 80mm fan fit perfectly and by 3d printing an expansion slot cover i should have no problems screwing the fan in place, any thought or advice on this plan ?
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
