Party like it's 1999 with a 6x86
First post, by badmojo
I thought I was done with building retro PC's but I happened upon an AT tower recently that got me thinking about a machine that was pretty significant to me back in the day (in hindsight). It was the last of the PC's I built from the spare parts resulting from my father's CAD machine upgrades; I was living under his house at the time in a converted garage, circa 1999. Technically an adult but only on paper - I was battling through a computer science degree at university, working as a kitchen hand, and being generally awkward and unsure about everything.
Details are hazy but I think the specs of that PC were a Cyrix 6x86, a Matrox Millennium, a Vibra16S sound card, with an unknown amount of RAM and HDD. I used it for web browsing (guitar tablature, etc), Uni homework, building simple websites (remember Hotdog?), MAME, and of course playing PC games. My meagre funds were increasingly diverted to drinking or keeping my car going so I was giving up on contemporary PC gaming at that point - going 3D wasn't cheap. Instead I played old favourites like DOOM, Duke3D, 4D Sports Boxing, and Network Q Rally. I’d gotten my hands on a knock off copy of CorelDRAW from somewhere so also produced several dubious artworks, like this when I was happy:
332.31 KiB
And this when I was sad 🙁
89.73 KiB
Against all odds I got my CS degree, landed a job in the city, and ultimately moved out of my garage home. There was nowhere to set up a PC in the tiny apartment I’d rented and I was busy killing braincells and racking up credit card debt anyway, so I dumped the 6x86 in a cupboard and forgot about it. A year later I moved into a share-house with more space, and DOOM in particular reminded me how much I loved escaping into a virtual world. My trusty old AT machine was a relic by that point though; when I moved in with my future wife a year later and I compared its specs to her PC and mine came up short, I unceremoniously dumped it on the nature strip and started planning an Athlon 64 machine. Sentimentality and nostalgia weren't something I did until recently, but I did at least have the foresight to copy off my dubious artworks, HTML, guitar tab, etc.
And now BAM, it's 15 years later. I don't think this is the exact case but it's pretty close:
The original only had a 2 digit display, set to HI and LO. I must have gotten a bee in my bonnet about airflow at some point because I distinctly recall drilling holes in the bottom of the front bezel - these 6x86s do get pretty hot.
This "new" case is in pretty good condition but was very dirty - the PSU was too awful to contemplate so went directly into the bin, and there was sand everywhere for whatever reason; even inside the CD drive. The plastic wasn't yellowed and the paintwork was generally good, after some minor touching up.
For a CPU and motherboard I just went with what I had in my spares pile - a Cyrix 6x86MX PR233 and a GA-586T2. The PR233 of course doesn't run at 233MHz, it's a 188MHz part that the Cyrix marketing department rated as being equivalent to a 233Mhz Pentium. I must admit that I'd forgotten about that trickery and was initially confused and anxious when Speedsys reported a frequency of 187.5MHz, but the penny dropped soon enough.
The motherboard was easy to work with for the most part - I updated the BIOS for no particular reason and was pleased to find that I had the PS2 mouse backplate stashed away. There's a USB header too but I haven't bothered with that - the IDE -> compact flash adapter makes transferring files just as easy. In saying that though the CF adapter caused me several hours of frustration because it turns out that having it as a slave on the primary IDE port caused the system to wig out occasionally. I was able to install Windows 98 initially but then files were becoming corrupted and partitions were going missing randomly. I suspected everything but the CF adapter because I've used those several times in other machines, but after moving it to being the master on the secondary IDE port it's all good and has been 100% stable since.
As a result of the CF adapter cluster fudgery, I went through several HDD, RAM, and VGA card combinations before the dust settled. I ended up with a 4.3 GB Seagate ST34311A HDD, 64GB SDRAM (max that the MB can cache), and a 2MB Matrox Millennium (faithful to the original).
Just for fun I ran Phil's benchmark suite and Chris' SVGA bench on several PCI VGA cards in this system as I put it together - Tseng ET6000, ARK Logic 1000PV, Diamond Stealth 64, #9 GXE 64, ATi Rage 2C. Some could equal the Millennium for speed and some are more compatible with old DOS games, but the image quality and nostalgia factor got the Matrox the gig.
Choosing a sound card is always the hardest part of any build for me and I got my knickers well and truly in a twist this time. I won't bore you with the details but I auditioned at least 10 cards (including some multi-card setups). After days of painful indecision I was left choosing b/w a nice Aopen AW32 Pro (Crystal S23A with CS4235 & onboard wavetable) and my favourite implementation of the ES1688 chipset (a Labway card). The Audiodrive gives some ground in sound quality but not by much, and I love ESFM. The CS4235 on the other hand has the worst sounding FM I've heard, so I would have had to pair it with a PAS16 and it all got too hard. For GM I snuck a Crystal CS9233 based wavetable card on - it's only 1MB but sounds great I think.
So far I'm loving this PC - it's 1999 all over again. Most of the games I've thrown at it run well but a couple - Network Q Rally for example - do chugg slightly with full details on (that's a SVGA game). It's workable but just for fun I've ordered a Cyrix MII-300GP (which really does run at 233MHz); I'll be interested to see how that handles SVGA.
Reply 1 of 23, by appiah4
That is not a Matrox Millennium 2MB but a Mystique 4MB I believe. 😀 Very cool PC though!
Reply 3 of 23, by keropi
heeh nice
back in the day when I upgraded to a ss7 system from 486/66 I also got the pr233 6x86 cpu , it was really fast in windows and apps.
But then I decided to play Quake 🤣 , the cpu lasted a couple of more days in the system and I traded it back to the shop for an intel 200mmx cpu paying some money difference...
Reply 4 of 23, by badmojo
Lolz right you are! That was one of the cards I tested but ultimately went with a Millennium, just uploaded the wrong pic. The Mystique is a great card too and shorter than the Millennium so could fit in any PCI slot, but WRAM is just cooler 😎
And yes Quake was really this chips Achilles' heel - it runs better than I remember actually but yeah, not great.
Reply 5 of 23, by badmojo
amadeus777999 wrote:
the CRT is nice... I dig the rounded tube.
Yeah I love that monitor - bought it NOS a while back. I have a couple of flat screens here too that have better geometry but the round tube feels right.
Reply 6 of 23, by Anonymous Coward
The only way you're going to party with a Cyrix 6x86 is if it's 1996.
Reply 7 of 23, by PcBytes
Not only that but by 1999 there were already Socket 7 machines with AGP.
Reply 9 of 23, by SpectriaForce
At my high school they had that exact same Philips monitor for some pc's. That's party like it's 2003 😊
Reply 11 of 23, by Gered
It's 1999ish if you were using it in 1999 (maybe it was all you could afford).
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 12 of 23, by badmojo
Yep it’s what I was using, but I can see where I went wrong. Thank goodness you guys were here to correct me.
Reply 14 of 23, by appiah4
The most fitting hardware for 1999 is what you remember 1999 by, so don't let anyone tell you it's not contemporary; have fun with your system! I think it has much charm.
Reply 15 of 23, by bregolin
I had a 486 DX4 oclked to 120mhz for most of 1999. As others have said, it's what hardware you had then that matters. Later that year I got an Athlon 550 and a TNT2.... and that changed everything 😀
IBM Aptiva 2162 - P55 166 MMX, 32MB, CS4237B + Wavetable, ATI Mach64 2MB / Win98SE
Custom PIII 750, 64MB, SB AWE64, Voodoo 3 3000 AGP / Win98SE
Sony Vaio z505 SuperSlim - PIII 550, 192MB, YMF744, NeoMagic 256AV+ / Win98SE
Reply 16 of 23, by GigAHerZ
At 1999 i had a 386SX 20MHz with 100MB hard drive running WfWg 3.11...
Reply 17 of 23, by Intel486dx33
paint it purple.
Reply 18 of 23, by DonutKing
I don't know about the rest of the world, but here in Australia computers were damn expensive, and people would run them for 5 years or more before upgrading. Seeing a Pentium class machine in regular use in 99/2000 was not unusual at all.
Reply 19 of 23, by Poulton
I second that. Gaming like back in the days is not about having the newest and/or high-end hardware from back in the days, that you couldn't afford or buy. 1999 i was using a K6 with 200Mhz, Trio64V+ and AWE64 Value.
