First post, by jforrest1980
Ok, the saga continues. Decided to just edit this post instead of make a new one.
I can't get the tomb raider glide patch to work. From my understanding since I have a Voodoo3 3000, I need to use the TomBrush patch. So I place that in the TOMBRAID directory. Detete TOMB.exe, and rename TomBrush to TOMB.
So I did that. Restarted my PC. When in dos and I try to run the command TOMB, I just get a prompt to insert the CD. Which is inserted obviously.
I'm using the Tomb Raider Special Edition for Win 95/98.
    1.9 MiB
Reply 2 of 5, by oeuvre
jforrest1980 wrote:
Alright, figured it out folks. My CD-Rom was going bad. Updated and things worked.
Was it suffering from ejectile dysfunction?
Reply 3 of 5, by buckeye
No telling how many "vogoners" suffer from this devastating condition!!! I lobby for the forming of a support group immediately!!! 🤣
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 4 of 5, by jforrest1980
It's OK fellas. My mom said a little ejectile dysfunction is perfectly normal on occasion.
