First post, by Predator99
Arrived today:
991.17 KiB
Looks new, but Driver Disk is just a copy. Cover is missing, hope its readable.
According to the manual its EGA/CGA comatible. Not sure about other features or PGC compatability. Output is analog at least.
1.07 MiB
714.97 KiB
Will test and post more when I have time 😉
Reply 1 of 5, by Predator99
Better pictures of the card:
1.16 MiB
1.21 MiB
943.24 KiB
And driver disk is working 😎
MVP1024-Driver Disk.rar
317.94 KiB
62 downloads
E:\
│ CGIDGIS.SYS
│ COFFLOAD.EXE
│ DGIS.EXE
│ DGIS.OUT
│ GEMFONTS.LST
│ GSSDGI.SYS
│ IMDOS.SYS
│ INSTALL.EXE
│ MVA.EXE
│ NECKEY.COM
│ PEGA3.SC
│ PEGA4.SC
│ PEGA5.SC
│ PEGA6.SC
│ PEGA7.SC
│ PGL.OUT
│ PGL640.EXE
│ PGLHIRES.EXE
│ README
│ SDEGA480.EGA
│ SDEGA480.SYS
│ SD_GDGI1.EGA
│ SETUP.TXT
│ VP1_1.TXT
│ XMODE.EXE
├───ACAD9
│ READ.ME
│ TSRADI2.EXE
│ TSRADI9.EXE
│ LIESMICH.VOR
├───CADVANCE
│ GS.DRV
│ README.DOC
├───CGI_DGIS
│ CGIDGIS.SYS
│ README.TXT
├───COMPVISN
│ DGIS.DEV
│ DGIS0.DIF
│ DGIS1.DIF
│ DGIS2.DIF
├───DGIS
│ DGIS.DRV
│ DGIS.GRB
│ DGIS.LGO
│ DGISAD9.EXE
│ DGISADI.EXE
│ DGISPREP.EXE
│ README
│ WINDGIS.BAT
├───VP
│ DGISPREP.DOC
Show last 35 lines
│       DGISPREP.EXE
│ GEMFONTS.LST
│ GSSDGI.SYS
│ SD_GDGI1.EGA
├───GEMFONTS
│ IBMPSS07.FNT
│ IBMPSS10.FNT
│ IBMPSS14.FNT
│ IBMPSS18.FNT
│ IBMPSS36.FNT
│ IBMPTR07.FNT
│ IBMPTR10.FNT
│ IBMPTR14.FNT
│ IBMPTR18.FNT
│ IBMPTR36.FNT
├───PCAD
│ DDGIS.DRV
├───PGL
│ IMADI.CFG
│ IMADI.EXE
│ IMCON.EXE
│ IMPCAD.DRV
├───WIN2
│ DGIS.DRV
│ DGIS.GRB
│ DGIS.LGO
│ README
└───WP5
DGIS.WPD
Reply 2 of 5, by Predator99
Manual:
581.18 KiB
NEC MVA 1024 Manual.pdf
1.81 MiB
86 downloads
Reply 3 of 5, by Predator99
Did a first test and tried to connect to a VGA Monitor with a standard DB9-15Pin Adapter. Did not display anything on my Samtron. But to my surprise it worked on my Dell 2709W!
Did not expect it because the output has composite sync.
It seems it booted with CGA enabled. When I try to switch to EGA mode sync is lost. But the 1024x768 mode also works.
1.6 MiB
867.17 KiB
Reply 4 of 5, by Predator99
As the Pin assignments were identical I tried to connect to my Thomson EGA/PGC monitor. It doesnt sync in the correct way. I disconnected at once not to damage anything. Therefore...the output of the MVA is not compatible to PGA..nice card anyway 😉
222.29 KiB
100.02 KiB
201.98 KiB
Reply 5 of 5, by Predator99
Got another specimen of this outstanding card for cheap. This time it also included the software manual.
PS: I am still searching for TIGAstar/tigacard drivers 😉
TIGA driver needed: Texas Instruments tigacard ("TIGAStar")
MVA1024 Software Manual.part1.rar
1 MiB
33 downloads
MVA1024 Software Manual.part2.rar
1 MiB
37 downloads
MVA1024 Software Manual.part3.rar
796.94 KiB
35 downloads
