First post, by weldum
hi, i have 3 s478 processors, the thing is that i don't know which would be better:
Pentium 4 2.0 SL6QM (northwood) 20x400
Celeron D 310 2.13 SL8RZ (prescott-256) 16x533
Pentium 4 2.26 SL7V9 (northwood) 17x533
what do you think guys? what would be the order?
thanks
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 10, by Errius
The Celeron. Two cores trumps two threads. And do those Northwoods even support hyper threading?
Is this too much voodoo?
Reply 2 of 10, by weldum
emmm i think you re way wrong, neither of these processors are dual core nor hiperthreaded, they're standard 1core 1 thread without 64bit support nor xd bit
Reply 3 of 10, by SPBHM
weldum wrote:
hi, i have 3 s478 processors, the thing is that i don't know which would be better: […]
thanks
1-Pentium 4 2.26 SL7V9 (northwood) 17x533
2-Pentium 4 2.0 SL6QM (northwood) 20x400
3-Celeron D 310 2.13 SL8RZ (prescott-256) 16x533
Celeron D was a lot nicer than Celeron Northwood but, it was still slower at the same clock than P4 Northwood, given the clock advantage and FSB it might give a hard time for the 2.0, but I think overall, the P4 will be slightly faster.
the positive of the P4 2.0 is that it would be the easiest to OC on FSB133 max boards, maybe.
Reply 4 of 10, by Errius
You're right. My bad.
Reply 5 of 10, by weldum
thanks SPBHM, i will change processors then
don't worry Errius, i think i may have been sound a little bit rude
Reply 6 of 10, by The Serpent Rider
SL7V9 is the latest stepping and probably overclock well.
Reply 7 of 10, by croton64
What do you want to do?.. C-D is more feature rich, P4 is faster due to double L2 size and extra 113Mhz (games!).. also Northwood runs cooler than Prescott, i'll choose P4 for gaming.
If you're planning to OC these things.. get some good cooling setup, it's not nice to have a little Chernobyl at the table :p.
Reply 8 of 10, by weldum
no overclock at all, is mainly games, and because of the gpu that i have available, there will be no games that will benefit from sse3 more than from the extra cache and clockspeed
Reply 9 of 10, by Tetrium
this would be my first pick.
What motherboard are you intending to use the CPU in? What's the rest of your system gonna be like?
My retro rigs (old topic)
Report spammers here!
Reply 10 of 10, by weldum
the systems ended up like this
p4 2.26
1gb
asrock p4vm800
fx5200 64 bit agp
p4 2.0
768mb
asrock ge pro m2
mx4000 32 bit agp
c d 310 2.13
512mb
asus p4bp mx
i845gv extreme graphics
