First post, by DaveJustDave
wanted something special to fill a niche between my 5170 and my K62-500 machine. Something versatile that will allow me to do bunch of dos and windows 98 gaming, so GLIDE was must.
I have a pair of voodoo 2's but i felt they were overkill for a 233, so those are going into my K6.
After seeing phil's 233mmx build, i perused what i had in stock and cobbled this together
Pentium 233MMX
MSI MB-8500TTD socket 7 motherboard
64mb RAM
Diamond Monster Fusion PCI
Matrix M3D powerVR
3COM PCI NIC
SB32PNP (I really need a proper AWE32)
Gravis Ultrasound MAX
Adaptech AH2940UW PCI SCSI Adapter
32gb HP 10kRPM ultra 320 SCSI drive
been stuck fiddling with IRQs and what not for a bit, but i think i have it sorted.
pile of parts during the parts selection process:
getting it hooked up on the test bench:
banshee's fan was really hard to spin. cleaned it out with some electronics cleaner, and put a drop of ceramic chain lube from my bike (all i had handy), spins ok for now. will have to replace the fan soon
ultimately when I'm done, my coverage will run from
tandy1000TL => 5170AT => 233MMX => K62-500 => 1ghz P3 Dell Dimension 4100.
maybe I'll stick a 386 DX40, or a 486 DX266, or a Pentium 75 into the mix somewhere, but I'm running out of desk space!
more to come
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 1 of 12, by chrismeyer6
That's a really nice system you got there. Great selection of parts I can't wait to see it finished.
Reply 2 of 12, by gdjacobs
Nice system, although i suspect the m3d card will be quite limited by the CPU.
Reply 3 of 12, by DaveJustDave
Yep, that card is going into my K6 when I finish THAT build. so many builds in the queue, so little time.
Reply 4 of 12, by PcBytes
Also, just an FYI, the board is a Biostar, not a MSI.
Reply 5 of 12, by badmojo
Groovy! What case will you be using?
Reply 6 of 12, by DaveJustDave
Sorry, typo! i was researching MSI boards for a bit before I wrote that post and it stuck in my head!
Reply 7 of 12, by DaveJustDave
it's a secret! But i can tell you this.. it'll be different than most other 233mmx builds you've seen!
Reply 9 of 12, by amadeus777999
Very nice build!
Does the Adaptec card need a driver in windows9x?
Reply 10 of 12, by SpectriaForce
Those black / bronze colored capacitors will need to be replaced (they start to bulge).
Reply 11 of 12, by DaveJustDave
amadeus777999 wrote:
Very nice build!
nope. worked out of the box with no drivers
Reply 12 of 12, by chinny22
Nice little system, although why do you think you need to upgrade to a AWE32? There isn't really any difference as long as you have ram installed
