First post, by PixelPolish
 - Newbie
Hey guys,
So I've had this "turn of the century dream machine" rig for a while now, but only recently I started really getting into some of the games from 97-99' to actually play them to completion. Mainly due to the fact that I've managed to snag a nice 1024x768 native res LCD monitor and got a dedicated space for this "beast". Games with native Glide support work pretty fine in 768p, but I've hit a major snag while trying to play Direct3D only games on my rig.
Now I remember full well that 3dfx cards were not playing well with D3D, but back around '00 I was still using S3 Virge/Voodoo 1 combo running on Pentium 166MMX with 16 megs of ram, before switching to nVidia (and skipping the Voodoo 3 card that I always dreamt of). My current Win98SE has Voodoo 3 2000, Pentium III 1GHz and 512MB RAM in it, so I was expecting (perhaps naively) that V3 would perform beautifully even in D3D games. Sadly that's not the case and it feels like there's something wrong with that configuration - either hardware or settings-wise.
For example, while playing SHOGO or Heavy Gear 2 in 768p, transparency effects like smoke, explosions or even windows cause massive slowdown. And not just the king that I'm used to, which is dropping frames, but the game still runs at it's normal speed. I'm talking literal slow-motion. like the game still wants to render all the target frames, but since the hardware can't keep up it takes it twice as long to do it. At moments like these the mouse movement feels like I'm treading through molasses, before it subsides when I either look away from the source of the problem or it vanishes. In HG2 even opening the Esc menu causes this slowdown and it's just 3 semi-transparent sprites for buttons.
Switching resolution to 800x600 helps considerably, but that defeats the purpose of my 1024x768 monitor which I've got specifically for this card so I can have the pixels be as sharp as possible. Now I'm not sure if that's V3's inherent problem, or if I can somehow remedy the situation. I have experimenting with different D3D settings in 3dfx Tools to no avail. Even turning off V-Sync doesn't make a dent. I have tried Amigamerlin and official 1.07 drivers with zero difference to the performance. Now I'm not sure if it's just those games being very poorly optimized or is there something I can do about it and it frustrates me to no end.
Any suggestions? Thanks.
The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man.
~George Bernard Shaw
