First post, by Lo-ResBros
I have a Rage 128 Pro 32MB PCI (Diablotek VAR 128-32P) card that won’t install windows 98 drivers using the latest drivers from AMD website or any other drivers from the vogons driver library. I get an error saying my video card is not supported with the drivers.
So instead, I’m able to force the drivers to install by updating the drivers and “have disk” option to search within the drivers folder. When I do that I get a list of all kinds of rage cards, all in wonder cards, and rage fury pro, but None of the options are my actually Rage 128 pro PCI card. The Rage Fury Pro driver option does install and seems to work good, but I just want to make sure I’m getting the most out of the video card and not losing any performance from using the rage furo pro driver.
pci.exe says:
Vendor 1002h: Ati Technologies
Device 5050h: Rage 128 PP/Pro PCI (TMDS)
*A note for others who might get one of these cards and may come accross this post. There’s like 6 surface mounted capacitors (22uF 6V) and I was having trouble with the picture till I replaced those caps. Might be a common problem. I was getting a glitchy picture with what looked like distortion. Replaced the caps and its crystal clear now
AMD K6-2+/550MHz
Soltek SL-54U5 Super Socket 7
64MB SDRAM
3DFX Voodoo 3 3000 16MB
Sound Blaster AWE64
Roland SC-55mkII
Pentium MMX 233MHz
Tyan TitanVX S1470 Socket 7
128MB SDRAM
ATi Rage 128 pro 32MB
Audio Plus 320 v.1
Roland SC-88
Reply 1 of 13, by luckybob
not to sound condescending, but if you google both cards, you would easily see the difference, and their similarities.
Reply 2 of 13, by fitzpatr
My understanding is that the Rage 128 Pro is the chip, and the Rage Fury Pro is the name of a released card which has the Rage 128 Pro.
Consequently, yes, they should be functionally equivalent for driver purposes.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 3 of 13, by luckybob
Ok, I'll need to apologise, I thought you said Rage Fury MAXX...
Jebus, I need to get some proper sleep.
Reply 4 of 13, by Lo-ResBros
All good. I did google search and I figured I was ok to use this driver for the card but I just wanted to verify and get a 2nd opinion
AMD K6-2+/550MHz
64MB SDRAM
Sound Blaster AWE64
Roland SC-55mkII
Pentium MMX 233MHz
128MB SDRAM
Audio Plus 320 v.1
Roland SC-88
Reply 5 of 13, by Lo-ResBros
Thanks for the confirmation and info 😀
AMD K6-2+/550MHz
64MB SDRAM
Sound Blaster AWE64
Roland SC-55mkII
Pentium MMX 233MHz
128MB SDRAM
Audio Plus 320 v.1
Roland SC-88
Reply 6 of 13, by Almoststew1990
I had this exact same question today so I'm glad this had come up!
ATI still has drivers for pre radeon cards on their site. It seems to be one driver for all these cards, released in 2002 I assume as assume kind of final "wrap up" legacy driver. Does this driver address the driver woes of the late 90s? Is it a good driver or do I need to go for an earlier one? For w9x
Reply 7 of 13, by Lo-ResBros
That’s the one I’m using and it is the latest driver avaialble. I’ve been testing games the past 2 days now and it seems to be working good.
AMD K6-2+/550MHz
64MB SDRAM
Sound Blaster AWE64
Roland SC-55mkII
Pentium MMX 233MHz
128MB SDRAM
Audio Plus 320 v.1
Roland SC-88
Reply 8 of 13, by SpectriaForce
I have made a topic about your driver installation issue: ATI Rage 128 Pro driver issue fix
Reply 9 of 13, by GulchWinder3D
What's the subsystem ID of your card?
I ran into a similar problem with my PCI Rage 128. After modifying the subsys ID for the entry matching my card's reported device and vendor IDs in Atii9xaa.inf I was able to get the drivers installed through ATI's setup utility without any error.
The card you mentioned seems to match this line:
"Xpert 128" = 128_DEFAULT,    PCI\VEN_1002&DEV_5050&SUBSYS_00081002
Change that "0008" to whatever 4 digit number is reported by PCI.EXE and give it another go.
Reply 10 of 13, by pinesal
Hello. Sorry to bring this old post back to life but I just did the exact same thing detailed in the OP here. I have a card that is labeled ATI Rage 128 Pro and the driver installer say that no compatible hardware was detected. I did manually install the driver just as described here. There were a bunch to choose from on the driver list including several entries with the same names. Like multiple Rage Fury and multiple Xpert Pro.
What I ended up picking was, "Rage Fury Pro/Xpert Pro 2000" I picked a few of the other also to test ("Rage Fury", "Xpert Pro") and they installed the same and looked the same and performed the same so I am not sure what, if anything, are the differences in the driver choices.
Am I missing out on anything by not running the installer proper? Is manually installing the driver just as well?
Hang out in the 90s with me on Twitch: The 90s Retro Gaming https://twitch.tv/90snick_pinesal
Retro Battlestation:
FIC VA-503+
AMD K6-2+ @ 600mhz
ATI Rage Fury 16MB
128mb PC100 RAM
137GB SSD
Windows 98
Reply 12 of 13, by Putas
pinesal wrote on 2022-02-04, 15:13:
Maybe some control panels.
Reply 13 of 13, by maw
had the same problem. thx for the hint
ASUS P/I-P55T2P4 (REV. 3.10) | Pentium1 233 | 32MB EDO | ATI Rage 128Pro 32mb | 3DFX Diamond Monster 3D | SB 16 CT2230 MT32-PI (DOS/Win3.11) | SB Live CT4760 (Win98) | 8GB Kingspec DOM | CD Drive | Dos 6.22 / Win3.11 + Win98
