First post, by retro games 100
Here is a 1MB STB Sprint/32 VL card, using the Trident chipset. I wonder what chipset it has? Is it the -
9400CXi (slow)
9440AGi (faster)
9440 (without a suffix) - fastest!
Quite some time ago, I talked about this card here:
My new old crusty 486 system
Thanks a lot for any comments!
608.85 KiB
Reply 4 of 7, by Cyrix200+
Also, I'd prefer to keep the sticker!
Edit: Google gives a number of different revisions/versions/PCB layouts of this card:
Different PCB:
http://www.ruleit.ru/node/377
https://retronn.de/imports/hwgal/hw_stb_sprint32.html
I'm also not sure if software is able to differentiate between the chip variations.
1982 to 2001
Reply 5 of 7, by The Serpent Rider
PCB layout and printed number can be misleading. These chips were pin compatible and manufacturers quite often didn't bothered to change anything on PCB.
Reply 7 of 7, by The Serpent Rider
It's 9440AGi or 9440. Only two options.
But FCC ID numbers are misleading too. I found exactly same card with what it looks like 9400CXi marking:
https://allegro.pl/karta-isa-stb-sprint-32-vl … 7692711487.html
