First post, by Jenot
I have Tekram DC-690CD EIDE/Floppy caching controller, but without legacy paddle board (with ISA header). I know which pins of ISA I should use (IRQ14 and IRQ15) but I have no idea where I can find DC-690 "legacy header" pinout. Controller is properly identified by my Intel Batman motherboard but I can't run Tekram's setup nor boot from connected hard drive. Maybe somebody here have this card and can check this paddle board pinout for me. TIA.
Reply 1 of 1, by vetz
I finally got around to start playing with my boxed version of the DC-690B. This was the only post I could find some info this card.
The attachment 2015-04-13 19.21.49.jpg is no longer available
Do you still need the pinout on the cable?
Some FAQ on the peddle board and controller:
https://web.archive.org/web/19970710121918/ht … s/DC6X0FAQ.html
If you configure it manually with IRQ 14 and 15 it might work without this board.
