So... I ordered one of them "shock absorbers" cheap from eBay, and got it in the mail today. Tested, using two identical drives, one without the shock absorber and one placed directly on the table. My table is one of them hollow ones, that transfers sound extremely good and so it was perfect for testing resonance from drives.
It eliminates roughly 2/3'rd of all noise, produced by resonance, and the sound from the heads moving are equally eliminated by the dampers. Of course this will have no impact on the noise the spinning platters produce. I think a case will make a barrier anyway, and I am testing drives that are not mounted inside a closed case anyway.
Another great thing is that I can mount a fan on it, yet heat travels up, so I am not shure why all these solutions have the fan location under the harddrive. Why??? Seems kind of strange to me. Personally, I will look for a solution that involves some kind of heatsink that I can mount on top of the drive and then air blowing from the front and back into the case.
I am happy enough. Cost me just under 11 Australian Dollars, to eliminate 2/3'rd of resonanse noise that are normally going into a case or were ever the drive is mounted. I just can't stand that noise. It is like the worst bad unpractised throat singing in my ears. This way I can spend more on a good fan. I know that Noctua is highly regarded for silent and reliable operation, yet what else is out there?
The attachment HDD-Shock-Absorber-01.jpg is no longer available
The attachment HDD-Shock-Absorber.jpg is no longer available
