First post, by kobalt
Hi,
I'm building an AMD K6-2 based rig for a friend, in a modern case.
This case has a front panel 4xUSB + audio jacks built-in, and the mobo is this gigabyte model : http://www.elhvb.com/mobokive/archive/Epox/ma … mu-mvp3g102.pdf
This system will run windows 98Se.
Obviously this mobo doesn't come with a front panel header connector, so I'm looking for a PCI adapter to get the front panel available. I mean the USB part, AC97 is optional (and has nothing to do with USB).
Of course this adapter has to be supported w/ Win98
I also have this card in spare :
Got it from a defective PC, never used it. Is the internal USB connector usable for my purpose ? (through an adapter i guess)
Any recommendations ?
Thx you
Cheers
Reply 2 of 3, by kobalt
Thx for your input, i'm going to give a try to this.
Reply 3 of 3, by chrismeyer6
Your welcome. It should work for you I've used that adapter in the past for the same thing
