First post, by Jed118
Hello,
I have a Precision T7500 Xeon (E5630, waiting on an E5649 upgrade) with 24 Gb RAM and plenty of scratch space in a RAID 0 setup . It is probably the fastest computer I have in here (II have a newer Phenom II 1055t 6 core lying around too)
I do my editing in Openshot 2.4.3 on Ubuntu 16.04. Video card is a GTX 650 (doesn't matter because all the rendering is done by the CPU) I realize the hardware specs are close to a decade old, however, can someone recommend a decent editing suite? I'm trying to edit a 720P dashcam file in AVI format (5 min file, about 550 Mb) and it's absurdly slow. Click to save - computer locks up for 5 mins. Click on Export? 3 min lockup. Cut the video file? 15-60 seconds of waiting.
It is pretty much unusable, but it wasn't always this way. Something is bloating this thing down, I think. I've also tried Openshot in Windows 10, and as soon as the file gets a little too complicated, or heaven forbid I accelerate some video, massive lag. I've also tried kdenlive, but it looks like a steep learning curve.
My goal is to create 10-15 min videos with some acceleration at times, a few effects (basic transitioning, sound track adding and volume manipulation, insertion of images) - closer to an MSPAINT piece of software rather than full blown Photoshop.
Recommendations?
What's for sale? my eBay!
Reply 1 of 11, by Beegle
1. What is the HDD (or SSD) where the file is stored? You say Raid 0, but don't say what type of storage.
2. Compression of file (or absence of) can have big impact. Some devices that create files on the fly, use codecs that encode quickly, to the detriment of decoding that will take longer.
Advice for 1 : Use a dedicated SSD for video editing media files.
Advice for 2 : Convert the file to a different format, codec, or even... uncompressed, before editing. In some editing software it can make huge differences.
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 2 of 11, by Jed118
I'm using two SATA hard disks (7200 RPM) at 500 Gb each in RAID 0. I also have a non-RAID drive in there at 1 Tb. I don't actually use it, I may just pull it out as I have a server I grab all the files I want to edit, make videos, and then the completed videos along with the assets I use go back on the server. Both OSes are on the same RAID 1 setup anyhow.
I thought about your second point a little after I posted this -I found that not all formats are created equally. I will have to do some research into compression vs. stream quality and optimize my setup. I don't need 4K resolution (hell 1080p is fine, otherwise people can see how hideous I really am 😜) or anything too fancy. I could also change the format of them before I do any editing as you mentioned.
Thanks for pointing me in the right direction!
What kind of hardware/software do you guys use, out of curiosity? I was very briefly like, damn, do I need a Mac for this or something? 😊
Reply 3 of 11, by root42
You definitely DON'T need a Mac to do video editing. That said, I DO use a 2013 iMac, lowest model with Core i5 and 8GB of RAM to edit my videos. They are all 1080p and editing is super smooth and fast. Export takes about 25-50% of real time though. So a 20 minute video will usually export in 5 minutes. All this using iMovie.
I do concur that you should probably use a SSD for editing though, since the transfer times are so incredibly better and you have virtually no seek times.
Still, OpenShot does have a hardware accelerated branch: https://github.com/OpenShot/openshot-qt/tree/ … ardware-support
You might want to try that out. Since you DO have NVIDIA graphics cards, it might just work with your setup. Should also help with encoding times.
YouTube and Bonus
Reply 4 of 11, by Jed118
I'm not sure what to do with that link's content. These are some kind of files for developers? The zip file has .dmg files here and there, is it for a Mac?
I get to here
Instructions
OpenShot Video Editor 2.x supports Linux, Mac, and Windows. But due to the many dependencies required to run OpenShot, we recommend using an installer for your operating system. Please visit http://www.openshot.org/download/ to find your correct installer.
so I just install the program from the terminal window? I already have 2.4.3 on there, will I have to remove it to reinstall one that has the hardware support for the GPU?
I'll try this when I get home:
$ sudo python3 setup.py install
Reply 5 of 11, by ratfink
I tried OpenShot on Windows but at the time I tried it, it seemed flakey and prone to crashing to desktop. I ended up using Davinci Resolve [the free version] from Blackmagic Design; I don't use it often but I like(d) the workflow/interface, it's packed with features and there are plenty of tutorials on youtube.
This was/is running on a Phenom II X4 965/8gb ram/Windows 10; it's available for linux. I don't think the version of Resolve I use(d) took advantage of the GPU, and as I recall some tasks do take a while to run.
https://www.blackmagicdesign.com/uk/products/davinciresolve/
That's the real site. NCH software seem to be trying to hijack it in search engine results. Well worth a look imho.
Reply 6 of 11, by WolverineDK
I have tried OpenShot on Windows, and I did not like it . On Linux though I highly enjoyed it. KDEnlive is a great video editing software on Linux, but personally I am not fond of it. But do not let that discourage you from using it. If you find fitting and great. So as others have said, you do not need to use a MAC to editing video.
Reply 7 of 11, by Jed118
Hey so I just tried to simply import two project files into OpenShot and the computer is having trouble with that... There has simply got to be a better way to edit video. I have spent over 8 hours editing down a 28min clip to a 3 min accelerated one with one or two pauses in the middle. I had to break it up into smaller pieces, remove the gibberish audio, do a fade in and a fade out. Exporting times were very lengthy (I got some assignments done in between, some house chores, changed my oil, etc) and the whole process seems like trying to boot Windows 3.1 on an 8088. But worse. Maybe on a 6510.
It seems that if there was a wrong way to edit video, I am following that path 100%. My channel has been slow to content because I have a massive backlog of footage that is just waiting to be edited. This is heartbreaking...
I'm going to level with you guys - I'm not a programmer, not nearly close to a developer. On a good day my Linuxing is 4/10.
I followed this thread :
https://github.com/OpenShot/openshot-qt/issues/1190
And it mentioned hardware support for GPUs (Nvidia) - it led me to the same link as above. I downloaded the large zip file and extracted it.
I have absolutely no idea what to do with this.
Maybe I need another Xeon for this computer... Brute force this mofo.
*Edit - seemed to catch a good groove, played around with different formats. I added a title and ending slide overlay and exported - lost half the video content in the middle of the file (no video, just my background music playing in the final export - retrying export so I have the whole footage only to add the title/end frames later - what an incredibly tedious process... Youtube videos make it look so easy...)
I can't be the only one who is having immense problems with this. This software won awards apparently? I guess it is free....
(looking into a used Mac 🤣)
Reply 8 of 11, by Jed118
After many, many hours of experimenting, here's what worked:
-Exclusive use of MTS format as project files
-Exporting to MP4 (H.264) when completed editing videos and effects EXCEPT TITLES
-Adding sound (narration, background music) - re-exporting
-Adding any labels or titles, re-exporting final.
I find that titles inexplicably drop video clips from the project and result in black segments (audio OK). I'm going to see how the "new" processor affects operation.
Reply 9 of 11, by Jed118
Alright, so the new E5649 6 core Xeon came in. I had to update the BIOS to get it to work (A02 to A18) and it made a difference.
Tips if anyone else is struggling:
-Do a BIOS update
-Go into said BIOS and TURN ON ALL THE THINGS! Multicore was disabled. Turbo was disabled. Some other performance options were disabled. I am not sure if these were always disabled, but they're on now.
-Upgrade the CPU.
-Latest version of OpenShot.
It's still a buggy program for sure (using the cut tool crashes it sometimes), so frequent project saving is a must. I am now compiling a new video with a few layers (labels, effects, fades, speed ups, etc) and it seems to be taking it quite well!
Additionally, watching Youtube vids while exporting - they don't skip nearly as much anymore. The real test will be the quality of the export when I play it back. That process is still quite slow, but at least I can do more in one shot now.
If it is still crappy, I'll try the suggestions for other software.
Thanks guys!
With that being said, back to editing!
Reply 10 of 11, by Geri
kdenlive. it takes a few hours to get used to it, its very similar to the old windows movie maker, with a few extra features (such as moving and rescaling layers around even as the video plays).
TitaniumGL the OpenGL to D3D wrapper:
http://users.atw.hu/titaniumgl/index.html
Reply 11 of 11, by pentiumspeed
Keep in mind the first gen processors that use this socket is no faster than C2D that was replaced. For this reason, I skipped both first gen and second gen (Sandy Bridge) and went straight to Ivy Bridge Xeon E3-1680 V2 on Z220. From Optiplex 780 with E8600 was my long term PC starting with XP, then 7 then Win 10. How I know? I played with T410 and knew how much performance was had even using i7-640M and had T420 as well , not much bump in performance.
Most performance boost is with Sandy Bridge or Ivy Bridge stuff and still compatible with XP which you're based on and as cheap too. Z210 takes Sandy Bridge i7 or Xeon. Another one is Z220 takes either i7 or Xeon using Ivy Bridge. Suggest Z420 if you want to keep XP and if your requirement is more than 32GB ram.
Cheers,
Great Northern aka Canada.
