First post, by Almoststew1990
I'm beginning to think about doing my own dodgy cooling on my lower power kit. For instance I have a Via C3 integtrated CPU motherboard which has a tiny heatsink and loud fan. I've currently replaced it with a large chipset heatsink which happened to have the same mounting diameter. It's really hot so I am thinking of getting a bigger one and maybe a large slow fan on the case. It's got me thinking whether anyone has ever made their own CPU / GPU / RAM / VRAM heatsinks out of things like:
For a CPU or GPU, it has a 50mm height which is the largest I've come across so far (cut the length/width it to size)
https://www.ebay.co.uk/itm/Aluminum-Heatsink- … b2t1Y:rk:9:pf:0
https://www.ebay.co.uk/itm/2X-100x69x36mm-Alu … T6/332872165362
For V/RAM, these are the largest (vertical) I can find.
https://www.ebay.co.uk/itm/Aluminium-28-x-20- … cs/362275975180
Stuck on the chip with (if no mounting holes obviously)...
https://www.ebay.co.uk/itm/Double-Side-Therma … MM/132899660521
Or just one long, narrow strip of the first heatsinks.
In particular I have a MX440 which has a chipset heatsink on it (I've had a lot of dead motherboards recently 🙁 ) which I was looking to replace with a larger heatsink.
I suppose my main concern is that these high heatsinks, whilst looking impressive, are quite industrial and aren't very "dense" and might not actually have a very large surface area for cooling. E.g a 30mm high heatsink with 8 fins would cool about the same as a 50mm high heatsink with 5 fins, as they have the same surface area (discounting materials, base thickness etc). The second heatsink I linked might be better at cooling.
So has anyone else played around with this sort of thing? added heatsinks to VRAM to help overclocking or anything?
Reply 1 of 1, by Windows9566
I have a lot of dead s462, s478, s754, etc. boards, they have heatsinks on the chipsets, i used 1 for my 486
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
