AMD K6 Quake2 and Quake 3, aiming for stars.
Reply 20 of 109, by Necrodude
A little update.
I have tried a lot of drivers.
12.46 is still the fastest driver.
I have done a lot of cfg tweaking in quake 3 and some write combining tweaking.
My fps in quake 3 have now reached a wooping 96 frames per second in demo four.
I have also aquired a Geforce 256 DDR, that card pushed the fps a tad further. 98 fps.
If I turn of the sound in Quake3 Im getting 168 frames per second. But I cant play quake3 on a RetroLan without sound.
Reply 22 of 109, by Necrodude
Im am using a AWE64 sound card.
My systems specifications right now.
Motherboard: ASUS p5a rev 1.104
CPU: Amd K6-3+ 400 @617mhz
Graphic card: Geforce 256 DDR.
Network card: Intel® PRO/1000 GT Desktop Adapter
128mb cl2 PC133 sdram
Reply 23 of 109, by cyclone3d
Do you have a PCI sound card you could try?
If I remember correctly from back in the day, ISA sound cards can kill performance compared to PCI sound cards. A Sound Blaster Live! / Audigy / Audigy 2 would be good choices for games in Windows. An Aureal Vortex 2 would also probably be fine.
I really should test that again (ISA vs PCI sound cards) since that was a really long time ago when PCI sound cards first came out.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 24 of 109, by Necrodude
I have tried a couple of different sound cards. Both PCI and ISA cards.
I stubled across this video and decided to try the awe card. And the AWE card is the fastest so far
https://www.youtube.com/watch?v=TC01uiyuJxI&t=1235s
Go to 7:33 and see the scores in quake 3.
I have also tried alot of different network cards. So far the INTEL card has been the fastest. It beats every 3com an Realtek card I have tried.
A friend of mine discovered the ADM tech card were crasy fast. Some day in the future I am going to test the same card he has.
One thing that is funny is how much faster Quake3 runs without a sound card. Im getting around 60 more frames per second without a sound card.
That got me thinking, about the sample based GUS sound card. I wonder If it is possible to get Quake3 to run on the GUS.
If I have understood it correctly, when a game have support for the GUS and it uses the samples, the card does all the sounds itself and doesent use your computers
cpu at all.....
That should give a big FPS boost if it were possible. But I doubt there is a patch for Quake3 that lets the GUS work that way
Reply 25 of 109, by Skalabala
Necrodude wrote on 2020-02-14, 22:22:
I have tried a couple of different sound cards. Both PCI and ISA cards. I stubled across this video and decided to try the awe c […]
cpu at all.....
Interesting that you say that sound card does not eat CPU performance.
All my K6 adventures shows that a sound card really hurts performance 🙁
We need someone to test this, I do not have such a sound card.
Last time I tested I was getting about 73fps in Q3
Reply 26 of 109, by Necrodude
I think that you must have misunderstood me.
When I have a AWE64 sound card in my computer, im getting around 96 fps in demo four in Quake3.
Without a soundcard I got 168 fps in demo four.
Awe 64 is by far the fastest soundcard ive tried. I have tried a SB live CT8370. Sound blaster 16. A yamaha OPL3 card. And a SB live SB0200.
According to phils video. Awe 64 is the fastest. And I could only agree
Im getting around 75 to 85 fps with the other sound cards
Reply 28 of 109, by cyclone3d
Skalabala wrote on 2020-02-18, 06:20:
Interesting that you say that sound card does not eat CPU performance. All my K6 adventures shows that a sound card really hurts […]
cpu at all.....
Hehe.. What systems specs do you want me to test with.
Motherboard will be an ASUS P5A-B
What CPU? I have pretty much whatever. By default I would use a K6-2+ or K6-3+
What soundcards?
I can test stock and overclocked speeds.
YMF7x4 Guide
Reply 29 of 109, by BinaryDemon
cyclone3d wrote on 2020-02-14, 21:55:
I think a few different scenarios need to be tested. I’m not sure PCI is always a winner depending on how much is put on the PCI bus - for example if you have a PCI videocard. In that situation I think having sound card and network card on the ISA bus might be better. I could be way wrong, I’d love to see some numbers. Obviously if using an AGP card, then PCI peripherals are probably better.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 30 of 109, by Necrodude
cyclone3d wrote on 2020-02-19, 17:23:
Hehe.. What systems specs do you want me to test with. […]
cpu at all.....
What soundcards?
Please test with a similar cpu.
The components in my system is as follows.
Motherboard: Asus P5A
Cpu: Amd k6-3+ @ 617 112x5,5
Graphics Card: Geforce 256 DDR
128mb Cl2 PC133
AWE 64
Intel® PRO/1000 GT network card
Do you have a Audigy 2 ZS?
Phil recently made a video about it
https://www.youtube.com/watch?v=RfmYYG1rVug&t=94s
Phil tested a lot of cards in this video as well
Reply 31 of 109, by cyclone3d
Ok.
I do have an Audigy 2 ZS..
I don't have a GeForce 256 DDR though. One of the cards that keeps evading me.
Not sure if I have a PCI Gb nic or not.
All my regular P5A boards are dead... So P5A-B it is. I could also test with an MVP3 based board as well.
YMF7x4 Guide
Reply 33 of 109, by Skalabala
cyclone3d wrote on 2020-02-19, 23:11:
Ok. I do have an Audigy 2 ZS.. […]
Ok.
Awesome. Use win98 with ALi driver 1.82, Nvidia driver 7.76 and CPU speed some overclock you feel is stable, 112x5,5 should be stable.
Sound cards you can use what you have.
Reply 34 of 109, by Necrodude
I forgot about this thread.
I did some serious tweaking with the Quake 3:s game files. I compressed all the textures and sounds, and removed unnecessary stuff.
I also got my hand of a geforce 256 DDR.
Then I broke the 100fps barrier! 😀
    27.78 KiB
    12.27 KiB
    9.42 KiB
Reply 35 of 109, by Necrodude
3dmark2000 score and cpu-z
    1.13 MiB
    1010.16 KiB
Reply 37 of 109, by Necrodude
Well. Without any tweaks and with vanilla Quake3 I got around 35 frames per second with a voodoo3 3000 and at 550mhz. Then I worked my way up to 100 frames per second.
Trying out different graphics card. The greatest performance booster is my Autoexec.cfg file that doubles the frame rate in Quake3
I think I used the 7.76 *12.46 detonator driver and the ALI 2.08 Agp driver
Edit: Sorry! I got it wrong
Reply 38 of 109, by Necrodude
And here is the latest cfg file. This config file doubles the frame rate.
Spoiler
Anyone up for the challenge?
Please beat my score! I dare you! 😀
Please do it with a sound card. Without a sound card I am getting 168 frames per second
