First post, by TheFifthRace
I’m using a Gotek USB floppy drive. The software I’m using is the ipcas Batch manager Tool V1.40. When I try writing floppy images using this software it doesn’t save the floppy drive label from the image. On the first disk I can sometimes get it to save, but any disk after that it will just make the floppy drive’s label FLPPY1, FLPPY2, etc.
What’s weird is if I do write image file, select my image, then do “save” it doesn’t save anything. If I do write image file, then open it, then save it, then it’ll save the image, but not retain the floppy label.
I’m just wondering if anyone else has this issue.
