First post, by candle_86
- l33t
Question I just bought one of these on eBay and Ivr heard they don't have l2. Does anyone have one and can link me which leads coast module I need
The board in the PB Multimedia F170 is a Intel NV430VX (Orlando)
it has 2 solder spots for cache ram chips
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Well shoot my solder skills arnt that good was hoping it used a coast module, I bet it's going to be quite slow without l2
so I've decided the slot layout of my 3 avalible PCI slots and 4 ISA Slots
I tried the onboard, max 800x600 with above 256 colors at the desktop and i can't stand it, also tried a Trio64V+ card I had in my parts bin, same issue don't like it
Specs as of now
Pentium MMX 166 @ 3.3V
8GB HDD Windows Boot Drive
40GB HDD Storage/ISO Drive
3.5in Floppy
DVD-Rom
ISA1 - AZT3000 Soundcard/Modem Combo was in the computer when I bought it, will replace with an AWE64 or SB16 later on
ISA2 - Open
PCI1 - Matrox Millennium
PCI2 - Matrox M3D
PCI3 - 3Com 100/10 Nic (Considering buying an ISA Nic so i can add USB to this comp)
ISA 3 - Empty
I have an F170 and it has a COAST slot for PLB cache sticks. Are you sure there isn't a longish brown slot above the CPU on your board? The cache really helped my system's performance. Mine might have rolled off the assembly line earlier (with a different board?) because the CPU is clocked the same but isn't an MMX. Also, I don't recognize the heatsink. I think mine has a fan on the CPU but I haven't had it open in a while.
Old precedes antique.
wrote:I have an F170 and it has a COAST slot for PLB cache sticks. Are you sure there isn't a longish brown slot above the CPU on your board? The cache really helped my system's performance. Mine might have rolled off the assembly line earlier (with a different board?) because the CPU is clocked the same but isn't an MMX. Also, I don't recognize the heatsink. I think mine has a fan on the CPU but I haven't had it open in a while.
positive, also mine has a Pentium 166, ebay add was wrong
wrote:wrote:I have an F170 and it has a COAST slot for PLB cache sticks. Are you sure there isn't a longish brown slot above the CPU on your board? The cache really helped my system's performance. Mine might have rolled off the assembly line earlier (with a different board?) because the CPU is clocked the same but isn't an MMX. Also, I don't recognize the heatsink. I think mine has a fan on the CPU but I haven't had it open in a while.
How weird. I'll have to take pictures of my board once I can get to it. If it's any consolation if your system's populated like the pic above with (256k?) cache your performance should be quite good and your stability should be excellent. I think I've got a handful of stability issues stemming from my 512K stick and its contacts.
Hello:
I am new to this site. I just got a PB Multimedia F170, and it was missing the hard drive and the ram. I'm in need of buying ram for it but I do not know which ram cards to buy. Can someone help?
72pin Simms Edo or fpm
