First post, by dvdmcwilliams
Hi to everyone, the matter is that I bought a second hand sy-5ehm motherboard, after check it I've discovered that one of the ceramic capacitors above the DIN port has burnt, (making the motherboard to not boot up at all, or continuous beeps randomly when power up without video) so i need to know if someone could help with the values of this missing component, thanks in advance!!
Link to the picture: https://i.imgur.com/njDRZTY.jpg
Reply 1 of 1, by rasz_pl
same value as C2
is one of the pads connected to one of the keyboard connector pins? if so it can be 47pF and doenst need to be there, could also mean keyboard controller chip is dead
in any case you need to clean up the area
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
