First post, by candle_86
Got my Quadro FX2000 but it's missing the mounting bracket and iddly the metal sheild around the connector. The card does work and I can get the sheiling from some dead cards, it's the bracket I can see a problem with. Anyone got any ideas on that.
It's dual dvi with s video in the middle
Reply 1 of 2, by candle_86
Considering buying something like a x1600 and robbing it's bracket they seem to match but them I'm destroying another retro for this
Reply 2 of 2, by FFXIhealer
The only way to not "destroy" another card like you say is to get a blank from somewhere, draw out on the thing with a permanent marker exactly where the holes need to be, and then drill it out yourself. Basically, make your own. Grind the edges with a small Dremel tool after you've cut the holes. I need to do this exact thing for an old Matrox Millenium G450 PCI card. It has dual-VGA outputs, but no bracket at all.
