First post, by borgbio
Hi,
The same problem was posted in this forum some month ago by another guy.
But there was never a solution posted, so I am trying again π
The Problem is with the game "Project Space Station" from 1987.
It is listed with DosBox 0.58 and 0.61 as Supported.
And most of the game runs just fine,
but very often during a shuttel launch, when the countdown is hold by mission command, the message is displayed and then nothink happens.
Total freeze.
I let the game run for about an hour but nothink happens.
If you are lucky some seconds after the message has displayed a new message appears saying "All systems go" and the countdown continues.
But it is realy frustrating to try and try again until it works, because launching shuttles is what you do most in the game π
So if there is someone out there who is smarter then me in bugfixing (which is about everybody out there), please help.
If you do not habe the game, you can get it at "The Home of the Underdogs"
*Removed. Direct linking not allowed. Qbix*
This link will direct you to the site where you can download it.
If you would like to sit hours and hours in front of your monitor, looking at some kind of machine code in search for the bug, you would have my gratitude *gg*
