First post, by CMC_DarkPhear
Well, in the last few days, DOSBox is causing my Windows 98 SE to bluescreen. The error message says something like (translating to english):
"A fatal error 00 happened at 0028:C023DB9F in V X D VDD (09) + 00001803"
And the worst part is that windows will be unbootable until I go to safety mode and REINSTALL MY VIDEO CARD (ARGH!!! REALLY ANNOYING!!!!!!!!).
I can't remeber doing any changes in my system lately, and DOSBox used to work fine, I've been using it to run Autodesk Animator... Also, it happens with every version of DOSBox I've tried. All other applications/games etc are working fine. Does anyone know what is the problem?
[EDIT]
I just found out when I enable DUAL MONITOR and turn on my TV (plugged to the PC), DOSBox works. Really strange...
Reply 1 of 1, by Markus
The latest nvidia drivers seem to be faulty.
Reinstall the drivers from the cd and try again.
