First post, by Butler2679
- Newbie
Related to STB Voodoo II
The 10mb voodoo 2 was used in Midway arcade machines. They can be found on ebay sometimes, but don't have PCI brackets.
Those are specifically stripped Obsidian V2s that just have less framebuffer memory (which is fine, as the games in question don't support more than 640x480 and even default at 512x384 anyway). They also don't have VGA passthrough nor SLI.
I have had a couple of these (still have one).
They are interesting cards. They seem to be intended for low resolutions with higher quality textures compared to an 8MB model.
If you've got a monitor with a second VGA input (or a VGA switch box) they work quite nicely. To be honest, a Voodoo 2 runs much better at 640x480 than higher resolutions anyway so it isn't much of a loss versus a 12MB card.
I have a pair of 12MB Voodoo2 cards in one of my systems and an 8MB version in another. From what I understand, the difference between 8MB and 12MB was they doubled each Texture Mapper's memory space from 2MB each to 4MB each. The Frame Buffer was 4MB on all cards. How does the 10MB card from the arcade machines differ?
2mb frame, 4mb for each TMU. Around that time arcade cabinets still rarely used high resolution and Voodoo 2 didn't had horsepower for a smooth 60fps above 640x480 anyway.
"AI Requires Proof That You Are Human"
