First post, by Deunan
Here is the seller's photo and more text below for those who like their CPU porn with a story:
The story: I was looking to buy a 40MHz-rated 387SX chip. Turns out it's not easy to find one (most top at 33MHz and won't operate reliably at 40MHz) so I got this motherboard to pull it out from. Wasn't expensive at all, some 30 EUR, no big deal. And the mobo is very interesting as well:
- it's a 386SX class (16-bit bus)
- but it has cache
- and VLB slots!
Now, cache on SX is rare as hen teeth. VLB slots? First time I see one of those. And the BIOS sticker says "486SLC", not 386. The CPU is missing though and it wasn't so much desoldered as ripped off, with 2 pads now gone as well - but I've repaired worse.
I started investigating the missing CPU, and got stumped. I'm pretty sure this was a 486SLC from the factory and never had a 386SX soldered in there. The 0ohm jumper resistors don't make much sense though when looking at Cyrix 486SLC pinout. Like, KEN# is connected but FLUSH# is not? SUSP# is tied high. Why bother?
So here's me thinking this had an IBM chip in it. I've heard those have different pinouts but so far the power pins check out, the bus ones (as far as I can tell) do too, only the special ones (N/C on a true 386SX) are a mystery. Plus there is a 3V3 voltage regulator there, the PCB is actually designed for a low-voltage 5V tolerant CPU.
I've dumped the BIOS and it's a pretty generic AMI except seems to have Power Management Setup entry, and there's one string that says "Alaris, Inc." - and that's a clue: https://www.cbronline.com/news/ibm_oem_pacts_ … rom_eteq_alaris
So, TLDR: I need to ID this board and make sure it had IBM chip in it. If it did, I might try and hunt one down to maybe try and repair it - I think it's a very cool mobo and could still live. I am also very much interested in any IBM docs for their SLC series, even a confirmed pinout would be of great help to me.
BTW both the GREEN MATH 4C87SLC-40 and the RAM I got with the mobo are OK and there's no battery spill so I'm rather confident it will work if the CPU is replaced and the 2 pads rewired.
